Is there a way to get a new ID tag for the glovebox? After I swapped interior, I need to replace the one for my car and not the other guys info. ( He needs the same for his )
theres no way to replace that. The only thing I can recomend to you, re swap back glove boxes, and have an interior shop color match and re dye the exterior of the gove box.
My friend does this for a living and he has always been able to match the color pretty much dead on.
The label will self destruct if you try to peel it off.
If your not concerned with the original box,you could cut around the label thru the plastic and make a copy of it and glue it to the new box.
Most any striping/decal maker could duplicate the label and type the VIN and codes on it,but likley would not since it is a felony to dupicate any veh componet containing a VIN.
