Radiator fluid change....?????
Old Oct 9, 2008 | 03:47 PM
kg54trains's Avatar
kg54trains
Default Radiator fluid change....?????
Looking to change coolent in C5-98. Checked the search of both forums with no luck. I want to change the coolent without paying a $140 fee to the GM dealership and have lost confidence in the local shops on changing the coolent in a C5. If anyone could give me a thread location I would appreciate the infor.
Old Oct 9, 2008 | 03:55 PM
VetteHunting's Avatar
VetteHunting
Previously posted by CF member Patches....
Draining and Filling Cooling System
Caution
With a pressurized cooling system, the coolant temperature in the radiator can be considerably higher than the boiling point of the solution at atmospheric pressure. Removal of the surge tank cap, while the cooling system is hot and under high pressure, causes the solution to boil instantaneously with explosive force. This will cause the solution to spew out over the engine, the fenders, and the person removing the cap. Serious bodily injury may result.
Important
If the procedure below is not followed a low or high coolant level condition and/or vehicle damage could result.
1) Park the vehicle on a level surface.
2) Remove the surge tank cap:
3) Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
4) Place a drain pan under the draincock.
5) Open the radiator draincock.
6) Allow the cooling system to drain completely.
7) Inspect the engine coolant for the following:
Discolored -- follow the flush procedure below.
Normal in appearance -- continue with the next step.
Notice
When adding coolant, use DEX-COOL® coolant. If silicated coolant is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will require change sooner-at 50 000 km (30,000 mi) or 24 months.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
8) Close the radiator draincock. Tighten.
Tighten the radiator draincock to 2 N·m (18 lb in).
9) Fill the cooling system through the surge tank.
10) Fill the cooling system with a 50/50 mixture of DEX-COOL® coolant and deionized water.
11) Start the engine.
12) Allow the engine to idle for 1 minute.
13) Install surge tank cap.
14) Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant temperature reaches 99°C (210°F).
15)Shut off the engine.
16) Remove the surge tank cap.
17) Start the engine.
18) Allow the engine to Idle for 1 minute. Fill the surge tank to 12.7 mm (0.5 in) above the COLD FULL mark on the surge tank.
19) Install the surge tank cap.
20) Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant reaches 99°C (210°F).
21) Shut off the engine.
22) Remove the surge tank cap.
23) Top off the coolant as necessary, 12.7 mm (0.5 in) above FULL COLD mark on the surge tank.
24) Rinse away any excess coolant from the engine and the engine compartment.
25) Inspect the concentration of the engine coolant.
26) Install the surge tank cap.
Old Oct 28, 2008 | 08:36 PM
rsiano@mac.com's Avatar
rsiano@mac.com
Default radiator drain **** does not look like ones seen in the past
I discovered the radiator drain **** on the 98 Vette does not look like any I had seen in the past. Instead of a brass fitting with two horns to assist in unscrewing it, I found a thin white plastic button sized **** which opened the drain in just a quarter turn with no threads. This was located on the right rear bottom corner of the radiator. I was really careful when I turned it afraid I would break the plastic. When I had it turned 1/4 turn, I pulled on it lightly in an rearward direction and after moving approximately 1/4 inch, the radiator began to drain.
I own an early set of the service manuals but no where did they show the location of the drain or what it looked like.
I have temporarily lost my digital camera and when I have it available again, I will post a picture of it. Perhaps one of you will post a picture of it.
Thanks!
Dick Siano
Old Oct 28, 2008 | 08:39 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Feel free to give me a call im local to you and i charge $75
To Radiator fluid change....?????
