HELP!! (with tires)
Old Oct 13, 2008 | 11:22 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Default HELP!! (with tires)
What is the biggest size tire that will fit on the rear with an 18" rim and be at least 26" high? Reason I'm asking is because I switched my stock wheels/tires to 265/35/18's on Z06 motorsports and the gap is way too big for the rear. The tires are 24 1/2" high and the stock tire height is
26". I don't want to lower the car at this time. So I need a bigger sidewall tire. Should I just go back to the stock size tire? Thanks for any input.
Old Oct 13, 2008 | 04:00 PM
D2-AUTOSPORT's Avatar
0D2-AUTOSPORT
Former Vendor
Are you looking to just get the stock run flat tires or are you looking for a conventional tire
