Headlight assistance needed!
Old Oct 16, 2008 | 10:38 PM
mtnchaz's Avatar
mtnchaz
6th Gear
Default Headlight assistance needed!
I have an '02 Coupe that the has a headlight malfunction and not sure if I need a new headlight, a motor or ...? The lid opens and closes without any problem but when the lid closes the motor keeps running. It makes a horrible noise for about 15-20 seconds, then will shut off. When I first had issues with this same headlight the lid would open but not close. I had to manually crank it shut. When bumped around a bit it started working fine and has continued to work until now. I am a woman with some mechanical know-how but this is way out of my league. Please advise as I do not want to spend money on replacing the wrong thing.
Old Oct 16, 2008 | 10:50 PM
coxjajb's Avatar
coxjajb
It's likely that you need a new gear in your headlight motor. See attached link.
http://forums.corvetteforum.com/show....php?t=1767764
Old Oct 16, 2008 | 10:51 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Sounds like you have a gear in the motor gone bad, Very common on the C5s, GM used plastic gears in them and they just don't last.
There is a brass gear fix you can get to fix it, I did it on my WS6 and it works just fine,
Bill K
http://www.rodneydickman.com/n113.html
Old Oct 16, 2008 | 11:17 PM
mtnchaz's Avatar
mtnchaz
6th Gear
Thanks to both of you, Bill K and coxjajb! I am new to the forum as of tonight and figured out the search after I logged my question. I have several issues with my car and was told this site is a wealth of information. Boy is it!!! Thanks again.
Old Oct 17, 2008 | 12:16 AM
Mr.Bill's Avatar
Mr.Bill
Welcome to the forum, You might want to fill out your profile, It is nice to know who you are.
Bill K
To Headlight assistance needed!
