Rattle on Low Speed Acceleration
Old Oct 16, 2008 | 11:14 PM
MadtownC5's Avatar
MadtownC5
5th Gear
Default Rattle on Low Speed Acceleration
So I took my 6-spd 2001 C5 vert in for an oil change before it gets put away from the Wisconsin winter. While I was there I had the dealer investigate a bothersome rattle I get at low speeds when accelerating. It happens in gear, but in any gear when the car is coming off idle speed. It isn't engine knock.
The service manager (they handle lots of Vettes) took a ride with me and said that the sound is normal on the 6-speed cars. Anybody heard this sound before? Clutch seems strong. I've had the car since May and plan on keeping it until the wheels fall off...or a C6 becomes too irresistible
Old Oct 16, 2008 | 11:18 PM
AEmedic's Avatar
AEmedic
The rattle can sound is normal, my 04 does the same thing if I don't keep the RPMs up.
Old Oct 16, 2008 | 11:23 PM
GK's Avatar
GK
Same here with my 04 too.
Old Oct 17, 2008 | 07:56 AM
homewrecker's Avatar
homewrecker
ditto
Old Oct 17, 2008 | 08:15 AM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
My 04 has a slight one also, but really didn't show up until I swapped out the stock shifter.
Old Oct 17, 2008 | 10:51 AM
poolboy's Avatar
poolboy
it is a common noise - so much so that I believe the video that came with them discussed that very issue.
Old Oct 17, 2008 | 11:05 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
My 02 had it and so does my 04....normal but.......don't know why they couldn't have made it so it doesn't do it. I bet if it was Japanese made it wouldn't be doing it.
Old Oct 17, 2008 | 11:09 AM
C02VETTE's Avatar
C02VETTE
Mine does it too. Is it anything to do with the torque tube? I have no idea what that thing does but the name sounds rattley.
Old Oct 17, 2008 | 11:25 AM
GK's Avatar
GK
Video?
Old Oct 17, 2008 | 12:40 PM
If it sounds like marbles in a can, then yes, it is normal for a 6-speed car.
Old Oct 17, 2008 | 01:09 PM
rickko's Avatar
rickko
Ditto! Same on my '04 MN6. You'll either adjust to it or learn how to take off without hearing it. GM has addressed this noise. It is a non-issue.
..rickko..
Old Oct 17, 2008 | 01:13 PM
Mad Dog Peter's Avatar
Mad Dog Peter
I back out of my driveway, throw it in gear, and as I slowly pull away, I hear the rattle. Yep, it's supposed to be common. Read this at southerncarparts:
Drivetrain rattling
The valvetrain makes a significant amount of noise at idle. It may sound like sewing machine. Converting the valve rockers to true shaft-mounted adjustable roller rockers with may help eliminate the valvetrain noise if adjusted properly. Installing a big cam and stiffer valve springs will make the noise louder.
On manual transmission cars (M6 or M12), the transmission sounds like it is rattling when leaving the line. It is normal. It is the clutch throwout bearing rattling around. Sometimes you'll hear a horrible rattle if you shut off the engine. If you press the clutch pedal in while shutting off the car, you won't hear it.
Old Oct 17, 2008 | 01:43 PM
GK's Avatar
GK
Is this issue related to the southerncarparts explanation about the drivetrain rattling?
I always shut the car down with the clutch in (after reading a post about it here). It doesn't completely eliminate the rattle, but it does eliminate the stares of awe as it's MUCH quieter.
Does shutting it down without the clutch engaged cause any damage? I figure not, but I might as well ask.
Old Oct 17, 2008 | 02:29 PM
Hams's Avatar
Hams
Cruise-In VII Veteran
Same here on my 2000.........Hams
Old Oct 17, 2008 | 02:35 PM
RedLS1GTO's Avatar
RedLS1GTO
I have been looking at EVERYTHING under the car trying to figure out what it was with no luck. I'm glad somebody posted this. Worst for me is going through the covered checkpoints getting onto the military bases. I either have to go higher RPM with my loud *** exhaust or rattle around at low RPM. Of course either way echoes... The gate guards don't appreciate the high RPM and the rattle sounds plain awful and is almost embarrassing!
Old Oct 17, 2008 | 05:47 PM
damilleniumboy's Avatar
damilleniumboy
What about A4's?
Old Oct 17, 2008 | 06:08 PM
C5nKY's Avatar
C5nKY
My 04 CE 6sp has it.
To Rattle on Low Speed Acceleration
Old Oct 17, 2008 | 06:21 PM
LAVetteLover's Avatar
LAVetteLover
Mine does the same thing.
It's normal on the 'vettes.
Old Aug 3, 2010 | 03:05 AM
ub5586@comcast.net's Avatar
ub5586@comcast.net
1st Gear
Default Clutch Rattle
I have an 04 that has the annoying clutch rattle that I have read about. The odd thing is I used to have an 02 with a 6 speed and it didn't make the noise. I have read that the 02 makes that noise too. Why do some rattle and others don't? Wish there was a fix. Sounds like a semi-truck clutch. Drives me crazy!!!!!!!!
Old Aug 4, 2010 | 12:11 AM
yaknow's Avatar
yaknow
, I really didn't notice until after installing headers and new sways. Been going to get under the car for the last couple of weeks but, haven't had time.
