Spark Plug Question!
Old Oct 18, 2008 | 03:24 PM
Ricks-LS1's Avatar
Ricks-LS1
Default Spark Plug Question!
I am getting ready to put AC Delco Iridium plugs in my 98 LS-1. Do you go with the factory gap of .060" or do you do something different?
Old Oct 18, 2008 | 03:26 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
No!!! .040!!!!
Old Oct 18, 2008 | 05:12 PM
ErnieN85's Avatar
ErnieN85
They are pregaped don't mess with them! just check and if one is different take it back
Old Oct 18, 2008 | 11:59 PM
itzza427's Avatar
itzza427
It will run great at .040 !!
Old Oct 19, 2008 | 05:04 AM
C5nKY's Avatar
C5nKY
Old Oct 19, 2008 | 06:36 AM
They come pre-gapped. Do not change them.
Old Oct 19, 2008 | 08:37 AM
csexton's Avatar
csexton
...and put a little anti-seize on the plug threads and Dielectric grease in the boots for easy removal next change
Chuck
Old Oct 19, 2008 | 08:56 AM
Jet-Jock's Avatar
Jet-Jock
Anyone know what the pre-gap is set to?
Old Oct 19, 2008 | 09:31 AM
JohnnyDee's Avatar
JohnnyDee
2023 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (performance mods)
2017 C5 of the Year Finalist
Originally Posted by jet-jock
anyone know what the pre-gap is set to?
.040
Old Oct 19, 2008 | 10:35 AM
ErnieN85's Avatar
ErnieN85
.040 last time I checked, although .060 would work fine and give a smoother idle.
Problem is they can be broken easily trying to change the gap
Old Oct 19, 2008 | 11:55 AM
10U 99's Avatar
10U 99
GM is pretty emphatic about not changing the gap.
it never hurts to check the gaps before installation. it only takes seconds and you never know when you might find a plug that has been treated rudely
Old Oct 19, 2008 | 05:54 PM
Jet-Jock's Avatar
Jet-Jock
Interesting, the owners manual says "Spark Plug PTJ16R15 (0.060 inch Gap)"
.020 is fairly large difference for plug gap.
Are we certain that plug is pre-set to .040?
Old Oct 19, 2008 | 06:01 PM
ErnieN85's Avatar
ErnieN85
Her you go straight from GM
Subject: Information on New Spark Plugs and Gapping #03-06-04-060A - (02/12/2007)
Models: 2004 Buick Rainier
2002-2004 Cadillac Escalade, Escalade EXT
2003-2004 Cadillac Escalade ESV
2004 Cadillac CTS-V
1997-2004 Chevrolet Corvette
1998-2002 Chevrolet Camaro
1999-2004 Chevrolet Silverado
2000-2004 Chevrolet Suburban, Tahoe
2002-2004 Chevrolet Avalanche
2003-2004 Chevrolet Express, TrailBlazer
1999-2004 GMC Sierra
2000-2004 GMC Yukon, Yukon XL
2001-2004 GMC Yukon Denali, Yukon XL Denali
2002-2004 GMC Sierra Denali
2003-2004 GMC Envoy XL
1998-2002 Pontiac Firebird
2004 Pontiac GTO
2003-2004 HUMMER H2
with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
Attention: Please disregard the Set Gap Per Vehicle Specification statement on the side of an ACDelco® Iridium Spark Plug Box. The statement will be removed from the boxes in the future.
• A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed.
• The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01 mm (0.040 in) when the spark plug is made.
Notice: The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
Old Oct 19, 2008 | 06:12 PM
Jet-Jock's Avatar
Jet-Jock
Interesting but the way it was worded they sure left some reading between the lines and assumptions to be made. They say ignore the reference on the box and state what the factory gap of the plug is and not to change it. But they never said this is what is approved for use as is from the factory in these vehicles specifically Corvette.
They should have worded it such that it confirms the proper gap when using this plug is .040 and this is approved.
Usually these things are scrutinized by legal, wonder why they left it open ended?
Old Oct 19, 2008 | 06:30 PM
ErnieN85's Avatar
ErnieN85
it's a tech bullitin for dealers & AC Delco mechanics. so it's implicit
Old Oct 19, 2008 | 06:33 PM
Jet-Jock's Avatar
Jet-Jock
That explains why they make so many mistakes when working on your vehicle.
Old Oct 19, 2008 | 06:59 PM
ErnieN85's Avatar
ErnieN85
Yep too many assumptions
To Spark Plug Question!
Old Oct 19, 2008 | 07:09 PM
Ricks-LS1's Avatar
Ricks-LS1
Just wanted to say thanks for all the responses. I've learned alot.
Old Oct 21, 2008 | 04:46 PM
Ryan040675's Avatar
Ryan040675
2004 Cadillac CTS-V
2004 Pontiac GTO
2003-2004 HUMMER H2
Ok I just ordered a set of these plugs, AC 41-985 and the part number on the plug is 12609877 NOT 12571164 as stated above...
WTF????
Do I leave these at the gap they're at now?
Are these a newer or older stock number GM is using?
Old Oct 21, 2008 | 09:53 PM
ErnieN85's Avatar
ErnieN85
part numbers change. Don't mess with them just check to make sure they are right and take back any that are not. for example if all are .040 and just one is .030 or .060 then take it back
