Its been a bad day went to the drag strip . blew my clutch got towed home . now what ? does anyone know where i can take it and what kind of clutch i should have installed ? i have a lift but scared to try by myself im willing to pay or trade for help to get her running again . its a 02 z06 42000 mi stock . thanks Roy
I was thinking it might have been a half shaft. Drag radials are great, but can be unforgiving to a stock rear. If that is what you find that is broke, you might want to go w/ harden shaft & put a DTE strut brace on while your at it. Good luck.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Lots of clutch packages out there to choose from. If you plan to stay stock, I wouldn't worry to much about it. Any of them will do just fine. If you plan to add some HP, you might consider one of the "upgrades". Personally, I put a Callaway flywheel/clutch/adjustable master cylinder in my '02, and I haven't looked back. You might also want to put a clutch bleeder in while you're at it.
Good luck!
i jacked it up put it in gear , cant spin drivers side wheel but the pass. side spins freely including the shaft and both rubber booths up to the rear end or diff. whats next ? does the diff. have to come out ?
There are several tiny clutch plates on both axles. This is what allows one wheel to rotate faster than another when you are making a tight turn.
When I was down at RPM they showed me that my backing plate for these clutch disks was cracked (it looks like a big flat washer). They also showed me some from other customers that were completely disintegrated.
Sounds like yours is busted and jamming up the works. They replaced mine with a stronger part that they make. It is it thicker and wider.
Yes, they removed the differential to fix that.
how lond did it take and how much did they charge id be happy with a good used one 342 or 373 yes mines not working its like its in netural thanks Roy
