Attaching new e-brake boot to that wire ring?
Old Oct 20, 2008 | 10:57 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
Default Attaching new e-brake boot to that wire ring?
Has anyone attempted to affix a new e-brake boot to the wire ring that holds the stock boot in place? I have an aftermarket boot, and it didn't come with a wire ring, so I took the old boot off its own ring by pulling the staples and fishing the wire out.
Now, I've got the wire fished through the new boot, but I can't find anything that will let me staple the rest of the boot around this wire and back onto itself. Standard staples are too small and weak; the larger staple guns don't have a backing plate to "fold the staple. Also, most bigger "standard" staplers have wide bases which won't let me get to half the locations I'd need to put staples at.
Is there a tool for this? Would a hot glue gun work perhaps? Maybe I could buy some snaps and put those on?
Thanks for any advice!
Old Oct 20, 2008 | 11:07 PM
Torch Red Tim's Avatar
Torch Red Tim
St. Jude Donor '09
I used a standard staple gun. Shot through the boot into some cardboard. Pulled off the cardboard then bent the staples down flat with a tack hammer. Looked like crap but it all gets covered up when you put it back in the car.
Old Oct 20, 2008 | 11:44 PM
Alaskanpilot
Hmm, didn't think about the cardboard trick. I have some 1/4" staples that my staple gun shoots out; I think those will work. Thanks for the tip!
Old Oct 21, 2008 | 09:27 AM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
The new boot doesn't need the ring. There are cut outs in the leather for you to use where the bolts hold it down.
Old Oct 21, 2008 | 10:10 AM
CarskinZ's Avatar
CarskinZ
Just use some spray adhesive and glue it back to itself. That is what I have my customers to do.
Chris
To Attaching new e-brake boot to that wire ring?
