DTC Code 1286 -there goes my weekend! (pic)
Old Oct 22, 2008 | 06:03 PM
homewrecker's Avatar
homewrecker
Default DTC Code 1286 -there goes my weekend! (pic)
Hi brothers and sisters! I got this code while on the freeway, with two hands on the wheel, looking straight and buying food for my sweet,, gray haired grandma. I know it's a Steering Sensor Bias Malfunction, after searching for a while and consulting the manual - I'm aware that I may need to rotate the steering wheel a full revolution left or right, but here comes a dumb question (s), How do you take the steering bolt off? Anything I should be aware off? Any short-cuts? Since I'm down there, what else should I do? I didn't go to no fancy school, and I have trouble just spelling anything. So, please be easy on me!
As always, your advice is always appreciated!
Below, picture of the victim - have a heart!
Old Oct 22, 2008 | 09:51 PM
homewrecker
ttt help!
Old Oct 22, 2008 | 10:07 PM
lil vette's Avatar
lil vette
Old Oct 23, 2008 | 03:45 AM
IDM's Avatar
IDM
thats one of the funniest written posts ive seen
Old Oct 23, 2008 | 05:25 AM
homewrecker
ttt I feel like i'm on the space station - I'm by myself...don't let me go in there alone!
Old Oct 23, 2008 | 02:09 PM
poolboy's Avatar
poolboy
Do an Advanced search on 1286 in just the C5 forums, and you'll see a bunch of hits on that code. This may give you some ideas on what others have done to fix it.
Old Oct 23, 2008 | 06:24 PM
homewrecker
I tried doing the searches, but nothing was real specific. I just want to know exactly where the steering box is, what areas to dismantle, and what to watch out for.
But thanks for the reply!
Old Oct 23, 2008 | 06:35 PM
homewrecker
Someone already had to experience this! What do I need to do to get more attention to this post? I wave to other corvettes all the time I'm a good guy, well I think I am. The only thing I got, is a vague manual, a dash of A.D.D. and a steering wheel that thinks I'm making u-turns all day! What do I need to do to get more attention to this post?
Want a picture of a pretty girl? You got it!
That's Natalie Portman...she's purrrty...
Can I get some advice now...please
Old Oct 23, 2008 | 06:49 PM
KonaVette's Avatar
KonaVette
St. Jude Donor '03-'04-'05
Did you already find this thread...
http://forums.corvetteforum.com/show...ight=1286+code
Old Oct 23, 2008 | 06:50 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Read this bru, it might be what you're looking for:http://forums.corvetteforum.com/show...highlight=1286
Searched C5 tech and found lots of hits for the 1286 code.
Old Oct 23, 2008 | 06:54 PM
homewrecker
Look how fast you guys got here! That's what i'm talking about! Thanks guys I will look!
Old Oct 23, 2008 | 06:57 PM
homewrecker
I saw that thread...but I thank you both! I'm nervous about dismantling the steering area since I never did that before, also I'm not sure what take out, what to watch out for...and finding the right bolt..
Aloha Kona! thank you sneakel!
Old Oct 23, 2008 | 07:22 PM
sneakelman's Avatar
sneakelman
Trust me bru, with the pics on that thread, and some common sense(aqcuired after seeing things in real time) you'll be just fine. There isn't anything that you can screw up really. Just keep in mind that you must pull fuse #16 AND disconnect the battery. Once you've done that, it's simply a matter of bolts, nuts, and connections. You may even be able to change it out leaving the column in the car. Try to pull the sensor off the colummn first. If it doesn't come off, then take the column out.
Follow the write ups, with pics, and you'll be cool man.
Old Oct 23, 2008 | 07:34 PM
homewrecker
Thanks sneakel, that kind of advice makes me fell a whole lot better. Thanks for taking the time out to help me!
Old Oct 23, 2008 | 07:36 PM
homewrecker
Thanks Sneakel! i clicked on the wrong link and click the correct one. It has a ton of info and for that my brother you are the best! I'll let you know what happens....you are the man!
Old Oct 23, 2008 | 07:40 PM
dobewillie's Avatar
dobewillie
lol a pretty face and everyone's got an answer way to go guys
Old Oct 24, 2008 | 06:59 PM
homewrecker
Dang! I hit my first curb in over 10 years! On my CCW's! I'm going to wet-sanded down, what rotten luck! I want to blame it on a girl, but yep...it was me. Another addition to my weekend of revenge!!!
To DTC Code 1286 -there goes my weekend! (pic)
Old Oct 24, 2008 | 09:00 PM
z06inVB's Avatar
z06inVB
I was prepared to do this after I got 1286 code. I checked the connector first. Turns out it was loose. Reset the code and no issues since.
Old Oct 24, 2008 | 09:09 PM
stormrider's Avatar
stormrider
I agree before you replace the sensor make sure the connections are on tight. If you have telescoping steering wheel and you have to replace the sensor try doing it without fully removing the column. Cobra4B, who is a pretty good wrench turner, and I spent an entire Sunday replacing my sensor, we never did get the connecting rod between the telescoping motor hooked back up after pulling the column, and the telescoping motor made pulling and replacing the column a nightmare On the bright side..... no more codes (knock on wood)
Old Oct 24, 2008 | 09:20 PM
homewrecker
Thanks Storm...How are you!! Thanks for always helping me out. I'll take the advice and I will let you know.
