12 Disk Changer Question
Old Oct 23, 2008 | 10:21 PM
veni vidi vert's Avatar
veni vidi vert
Default 12 Disk Changer Question
Is there a way to get the magazine to eject without a power source?
Old Oct 24, 2008 | 12:30 AM
veni vidi vert
No one???
Old Oct 24, 2008 | 01:33 AM
RedRckC5's Avatar
RedRckC5
Old Oct 24, 2008 | 02:21 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I have mine laying here and I don't see a way to get it out. When I removed mine I pulled all the cd's out and than put the magazine back in
Old Oct 24, 2008 | 09:47 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i have no clue but there may be a small pin hole near the eject button push a paper clip in there and it will release the cartridge
some changers have this some dont
Old Oct 24, 2008 | 10:35 AM
dndrsn's Avatar
dndrsn
I just put my changer back in my car and noticed that when you insert the magazine and slide the door shut, the changer immediately loads the disks from the magazine into the changer. When the door is opened the changer then loads the disks into the magazine for removal. Aside from dis-assembly I do not know how you could remove the magazine without power. If you could remove the magazine without power it would be without the disk carriers.
If you could identify the specific pins for 12v positive and negative, that would probably be all you would need for temporary power to remove the magazine.
To 12 Disk Changer Question
