Key fob not working
Old Oct 25, 2008 | 01:31 PM
WestonGrayc5's Avatar
WestonGrayc5
Default Key fob not working
I replaced the battery on my key fob for my 2000 coupe. Now it doesn't work. Put the old battery back in and it doesn't work now either. Any help?
Old Oct 25, 2008 | 01:38 PM
cklemmer's Avatar
cklemmer
6th Gear
Did you "resyncronize your transmitter" after the battery swap? I've had to do this several times, it's pretty easy. Instructions are in my 2000 manual on page 2-11 right after the battery replacment instructions
Old Oct 25, 2008 | 02:47 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Point it at the car while holding down the lock and unlock buttons until the horn beeps. If that doesn't work, pull up the TRAIN FOB option on your DIC and do it from there. All set.
Old Oct 25, 2008 | 02:49 PM
Bakersfield's Avatar
Bakersfield
Old Oct 25, 2008 | 04:08 PM
Larry Salsman's Avatar
Larry Salsman
Default Key Fob Not working.
I had this same problem last week. I did both things you said, but it will not work. I have even tried 3 times for both items. Just gave up. Any ideas?
Old Oct 25, 2008 | 04:17 PM
sneakelman's Avatar
sneakelman
Buy a new fob.
Old Oct 25, 2008 | 10:28 PM
WestonGrayc5
Thanks guys, holding down lock and unlock worked.
Old Oct 25, 2008 | 10:47 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
To Key fob not working
