Draining versus Flushing
Old Oct 26, 2008 | 04:46 PM
VETSTYL's Avatar
VETSTYL
Default Draining versus Flushing
Just had some work done on my car at the dealership and based on the number of miles that I have (100K+) he recommended that I have all my fluids flushed. Although I change more fluids regularly, I never 'flushed' anything.
Is this just semantics or is there a significant difference?
VETSTYL
Old Oct 26, 2008 | 06:24 PM
SUPERCRUZ's Avatar
SUPERCRUZ
You will get a lot of different opinion on this forum. This is my opinion and others may not agree. Your profile does not say if you have a manual tranny or automatic. If you are running an automatic trans, I would recommend you have your transmission flushed every 2 years or 24K mi. Flushing a trans using equipment such as the machine made by BG products will flush all the fluid out of the trans and torque converter whereas a simple drain and re-fill will only change about 1/3 to 1/2 the fluid. With over 100K mi on your car, I would get the shop to evaluate your trans fluid before flushing. If it is nice and pink and looks new, I think you would be okay. IF it is brown or smell of varnish, leave it alone. Flushing it now will kill the tranny.
I also recommend flushing for your power steering and cooling systems. BG makes flush equipment for these systems as well. If you are running Dexcool coolant, you can go 4 - 5 years before needing a flush. I would flush the PS every 3 years or so. Brake fluid can be changed using a power bleeder and should be changed annually or at least every 2 years. Good luck with it.
Old Oct 26, 2008 | 06:39 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
When you can flushing is always best. Within reason.
Old Oct 26, 2008 | 07:25 PM
TEXHAWK0's Avatar
TEXHAWK0
Flushing fluids like in the automatic transmission can be good if you do it regularly. However, if you wait too long, it can actually end up causing problems by breaking loose old deposits.
Old Oct 26, 2008 | 07:35 PM
vettelover84's Avatar
vettelover84
My experience is that Auto Trans and power steering fluid get flushed... For best results. Drain and refill good for the rest...
Old Oct 26, 2008 | 08:13 PM
dobewillie's Avatar
dobewillie
but it don't hurt to flush the cooling system
To Draining versus Flushing
