need power
Old Oct 27, 2008 | 03:36 PM
stewart11's Avatar
stewart11
Default need power
i have a 02 coupe with a bunch of stuff done to it. came out to about 430hp and 328 torque. a4 with 3.15 gears and a 2400 stall. can keep up with a stock c6 up to 130mph on track but then i get walked off on. any help or mods i can do
Old Oct 27, 2008 | 04:40 PM
vettelover84's Avatar
vettelover84
3.42 or higher gears will help. Nitrious. Twin Turbo Setup... FAST intake.
Old Oct 27, 2008 | 04:42 PM
happa's Avatar
happa
Go with a FAST 90 and then Nitrous! Alot cheaper than twins
Old Oct 27, 2008 | 04:43 PM
stewart11's Avatar
stewart11
Thought about the 3.42s. R they the best overall gears
Old Oct 27, 2008 | 04:45 PM
bucwheat's Avatar
bucwheat
If you were racing at the track that should do the trick.
Old Oct 27, 2008 | 04:53 PM
stewart11's Avatar
stewart11
thanks abunch. Will try that out
Old Oct 27, 2008 | 04:57 PM
vettelover84
not really sure. With an AUTO I would not know what would be the best streetable gears. But the 3.42s would give you a bit.
If you haven't already built your rear end, putting in a gear would help with the leaking but and give you a chance to install a DTE brace, and/or the new PFADT Trans brace!!
Old Oct 27, 2008 | 05:02 PM
50th@50's Avatar
50th@50
Are your numbers right ? Why 100 more HP than torque ?
Old Oct 27, 2008 | 05:05 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Old Oct 27, 2008 | 05:11 PM
black98c5's Avatar
black98c5
What's the rest of your setup? Cam, CAI, LT's .....???
I would definitely get gears. I'm running 3:73's w/SS3600 stall and IMO is the perfect combo.
btw, your TQ #'s seem kinda low
Old Oct 27, 2008 | 05:34 PM
stewart11's Avatar
stewart11
thats what they told me. 21st century did it. confused as u were
ligenfelter heads/cams
ported throttle body
hurricane intake
bypass tube
b&b short headers
x pipe
corsa exhaust
24 stall converter
thermastat
stock 3:15 gears
biggest cam u can get for auto
Old Oct 27, 2008 | 05:40 PM
4DRUSH's Avatar
4DRUSH
hurricane intake
bypass tube
b&b short headers
x pipe
corsa exhaust
24 stall converter
thermastat
stock 3:15 gears
Old Oct 27, 2008 | 05:42 PM
50th@50's Avatar
50th@50
somethings not right, I have 03, A4, 3:15, Just BB Shortys, twin cone and Flowmasters and smooth coupler = 347 RWtorque.
Did they provide a dyno chart ? The C6 you refer to above,is it LS2 or LS3 ?
Old Oct 27, 2008 | 05:45 PM
stewart11's Avatar
stewart11
ls3
Old Oct 27, 2008 | 05:46 PM
stewart11's Avatar
stewart11
b&b isnt good
Old Oct 27, 2008 | 05:59 PM
ALVETTE00's Avatar
ALVETTE00
If you have 430 rear wheel HP where is no way you would get walked by a stock C6, period.
That's what the LS3 is rated at the crank.
Something is fishy my friend.
Old Oct 27, 2008 | 06:01 PM
stewart11's Avatar
stewart11
thats what i say. may b tuned wrong
To need power
Old Oct 27, 2008 | 06:19 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
The math just isn't adding up. Did they give you the dyno sheet?
Old Oct 27, 2008 | 06:29 PM
stewart11's Avatar
stewart11
yes 310.2 max power 311.6 max torque run #1
430 max power 328.3 max torque
thats all i have on it. did it a year ago
Old Oct 27, 2008 | 07:02 PM
kjmj's Avatar
kjmj
something is not right. take it to corvettes of dallas. they are doing 3 pulls for $39. i would start there to confirm your #'s are right.
