torque vs. H.P., whats better ?
Old Oct 27, 2008 | 03:42 PM
50th@50's Avatar
50th@50
Default torque vs. H.P., whats better ?
OK, moving right along then, my particular Vette measures 331RWHP and 347RWTorque, would my car be faster the other way around ??
Why do some cars have HP and torque about even, some, HP is much higher than torque and others, like me the torque is higher than the HP, why the 3 different seperations, is it the tune ? Gears ?
In laymans terms, how would you define HP and then torque ? Why do I ask so many questions?
My quess is torque is better, dunno really.
Thanks,
Old Oct 27, 2008 | 03:47 PM
BT-01-vette's Avatar
BT-01-vette
Hopefully someone will chime in for ya but if you post this in the tech section....that is where the gear heads hang out
Old Oct 27, 2008 | 04:15 PM
RespondsWithGif's Avatar
RespondsWithGif
The amount of hp and tq an engine has depends on how the engine is setup. If it is a high rpm engine it will have more hp than tq pretty much every time. Our engines dont rev real high so you will see the tq and hp values be about the same. All engines that rev below 5200 rpm will have more tq than hp.
As to which one is more important, it would be torque but not just torque.. it has to do with how high it revs and what the gearing is like. Gears multiply torque so you will want your gears to be as short as possible when you you accelerate (so you will have more thrust). But there is a down side to aggressive gears... if your engine does not rev high enough then you cant go too crazy with the gearing because you will be shifting too often and the terminal speed in each gear will be reduced.
Horsepower will give you the best idea on the performance of a car though. High hp and low tq cars can be geared very aggressively to make up for the lack of tq. Usually you will see cars with similar hp to weight ratios perform pretty close.
Im not real good at explaining some of this but if there is anything you want me to elaborate on let me know.
Old Oct 27, 2008 | 04:16 PM
Traxx999's Avatar
Traxx999
HP is how fast you get to the tree, Torque is how far you take it with you
Old Oct 27, 2008 | 04:20 PM
happa's Avatar
happa
Some of the reasons are cam swaps. Usually in most cases you'll get more HP than TQ with a larger cam. But if you dont like it you can always spray it (see my sig for example)
Old Oct 27, 2008 | 05:04 PM
karateboi87's Avatar
karateboi87
I read an article about this a while ago. It explains how you calculate torque and horsepower. I think at like 4500rpm (somewhere around there) HP and TQ are equal. I don't remember the details, but you can just google this.
Old Oct 27, 2008 | 05:29 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Lol
Torque is instantanious power. HP is power at a certain engine speed. Think of it like this:
A waterwheel creates a LOT of torque, but the speed is rather low so the HP is low
An average walk-behind mower motor spins rather quickly and has 5-7hp, but doesn't have a lot of torque to cut un-tamed grass.
Personall Tq and HP take a back seat to lbs of thrust
Old Oct 27, 2008 | 06:07 PM
RespondsWithGif
5252rpm
Originally Posted by TheRadioFlyer
Lol
Yep, and thrust is calculated off of tq, gearing, and tire diameter.
Old Oct 27, 2008 | 06:13 PM
50th@50's Avatar
50th@50
I was doing ok understanding but then 'thrust' entered the equation ?
THRUST, isn`t that for a jet engine ? Bubbles from the Chi-Chi Room, she has excellent thrust.
A dyno chart would show correlations at various RPM`s very well, I think.
Old Oct 27, 2008 | 06:20 PM
C5SCCA's Avatar
C5SCCA
Torque is a rotational force. It is a measurable quantity. Horsepower is a derived quantity. By definition, it is impossible to have horsepower with out torque. 1 hp = 550 ft-lbsf/sec. We can also rate our cars power using Watts...the common measure of the power of a light bulb. In fact, most European cars use the Watt as the standard measure of power in automobiles. The term horsepower gets thrown around so much it is no wonder why the confusion exists. As to which is better, the question is impossible to answer, at 5252 rpm they are equal. It depends on the application.
Old Oct 27, 2008 | 06:21 PM
DaveK88's Avatar
DaveK88
Not to hijack the thread, but sometimes you see just HP for horsepower and sometimes you see bhp. what dose the "B" stand for?
Old Oct 27, 2008 | 06:25 PM
hotwheels57's Avatar
hotwheels57
Horsepower...
http://en.wikipedia.org/wiki/Horsepower
Torque...
http://en.wikipedia.org/wiki/Torque
Torque is what you feel in your buttnometer. Horsepower is what you bench race.
BHP...
SAE gross horsepower
Prior to the 1972 model year, American automakers rated and advertised their engines in brake horsepower (bhp), frequently referred to as SAE gross horsepower because it was measured in accord with the protocols defined in SAE standards J245 and J1995. As with other brake horsepower test protocols, SAE gross hp was measured using a blueprinted test engine running on a stand with no belt-driven accessories, air cleaner, mufflers, or emission control devices and sometimes fitted with long tube "test headers" in lieu of the OEM exhaust manifolds.[citation needed] The atmospheric correction standards for barometric pressure, humidity and temperature were relatively idealistic. The resulting gross power and torque figures therefore reflected a maximum, theoretical value and not the power of an installed engine in a street car. Gross horsepower figures were also subject to considerable adjustment by the manufacturer's advertising and marketing staff under the direction of product managers.[citation needed] The power ratings of mass-market engines were often exaggerated beyond their actual gross output, while those of the highest-performance muscle car engines often tended to be closer in actual output to their advertised, gross ratings.[citation needed]
No pre-1972 engine in its unaltered, production line stock form, as installed in the vehicle, has ever yielded documented, qualified third party validated power figures that equal or exceed its original gross rating.[citation needed] Claims that such engines were "under-rated" are therefore dubious; for example, the 1969 427 ZL1 Chevrolet, rated at 430 bhp (320.7 kW), is frequently cited[who?] as an "under-rated" high performance engine, yet it produced only 376 horsepower (280 kW).[9
Old Oct 27, 2008 | 06:27 PM
C5SCCA's Avatar
C5SCCA
The use of thrust is not necessarily accurate in this situation. A thrust is internal to a system. Thrust is a force which acts equally and opposite a system or mass.
Old Oct 27, 2008 | 06:31 PM
WKMCD's Avatar
WKMCD
There is no simple answer. It depends how YOU want to use the car. For drag racing, peak RWHP is king since you're always in the upper RPM. For overall driving, autocross and road racing, you would want a power curve that enables you to merge and come out of corners without having to rev the engine sky high or wait to make power.
This is my dyno graph. I make 380 RWT at 2200RPM and 400RWT from 3k up. Tip is is insane and I can roast the tires from just off idle. The average power is usable and a blast to drive.
Old Oct 27, 2008 | 06:34 PM
50th@50's Avatar
50th@50
Aha, so you mean like, "for very action there is an opposite and equal re-action"? Wow kinda gettin more complicated, so keeping it simple for a simpleton like me, and using Bubbles (something I am more "learned" about), she does something, a movement or sequence with more "energy" and I throw more "higher energy" money, like that or ?
Old Oct 27, 2008 | 06:38 PM
mcrams's Avatar
mcrams
Pretty accurate description, in layman's terms. Thanks.
Old Oct 27, 2008 | 06:54 PM
C5SCCA's Avatar
C5SCCA
Haha, your first part is right. I am not sure about Bubbles though.
To torque vs. H.P., whats better ?
Old Oct 27, 2008 | 06:55 PM
Dominic Toretto's Avatar
Dominic Toretto
I like that answer.
-Alex
Old Oct 27, 2008 | 07:21 PM
02MillenniumVette's Avatar
02MillenniumVette
Torque moves mass so torque is better. Hp is a measurement of torque.
Old Oct 27, 2008 | 08:40 PM
lionelhutz's Avatar
lionelhutz
If you just give a rear wheel torque number and a rear wheel HP number then they are useless to compare to another car. You need to know the rpm at those number or even better the torque curve and rpm curve.
Torque is a force causing a rotation.
HP is the measure of how much work that torque does.
HP = Torque x rpm / 5250
1 HP = 33,000 lb-ft per minute.
A simple example - lifting a 1lb weight 33,000ft in 1 minute is 1HP of work done.
If you kept lifting for 1 minute at 0.99999lbs of force so didn't actually move the weight then you would have done no work - 0 HP.
The important parts;
If the torque is the same and the rpm goes up then the HP is greater. Many people say torque gets you out of the hole and HP is the top end acceleration but that's not really true. It's just that the torque is always greater than the HP below 5250 rpm. Simple math. Many people wrongly think that since torque is a greater number it must have a greater effect on acceleration down low.
The most available rear wheel HP over the operating range of the engine will make the car accelerate the quickest. You could have a low revving high torque engine or a high revving low torque engine and still achieve the same basic goal. It all depends on the torque curve, gears and such how that torque is converted to rear wheel horsepower.
This is the reason you want to get the engine up in rpm at the top of it's power band. Sure, the LSx engines have a nice flat torque curve but with a completely flat torque curve you always have more HP at a higher rpm. So, get the rpm up and the car accelerates quicker. Gears allow you to do this. A nice spread between gears helps too. The new cars with the CVT (continually variable transmissions) should in theory accelerate better because the engine can be put at the rpm where the best power transfer to the ground occurs.
Not true. HP and torque are not measuring the same thing.
Peter
