Meziere Electrical problem - Zip Prod. Harness
Old Oct 29, 2008 | 08:31 PM
Fratbragen's Avatar
Fratbragen
Default Meziere Electrical problem - Zip Prod. Harness
OK, got everything in and hooked up. Went well, up until now. For the electrical part of the instal I bought Zip-Prod E-911. It's a "plug and play" relay that won't let the fuel pump run if the water pump isn't. However, it plugs directly into the fuse box. The instructions say to plug the relay power wire into Fuse #6 - O2 Sensor. However, the O2 is fuse 15. Then it says to plug the Pump Power into fuse #20 which isn't an active fuse!!! I'm completely confused and wondering if anyone else was suckered by Vette Magazine to buy this thing.
Any and all help is very much appreciated!
