Can plug as a temporary fix, but the correct long term fix specified by Goodyear, is to have tire removed from the rim, and install a combination plugg/pactch, which kind of looks like a mushroom.
Goodyear claims that by using a normal plug, you lose the speed rating on the tire. Even by using the mushroom plug for a third time, supposedly, you lose the speed rating.
Ed
, but replace them when they are shot with regular tires. Way better ride and handling. I carry a compressor, compact jack and a plug kit. After the temp fix I have the flat professionaly fixed by a pro shop with the plug/patch kit.
