Window Valet Problem! there goes my weekend!!
Old Oct 31, 2008 | 08:03 PM
homewrecker's Avatar
homewrecker
Default Window Valet Problem! there goes my weekend!!
Man oh man, I need your help forum. I have a window valet that usually rolls both windows down when I press the unlock button 3 times on my fob. Now, only one window (drivers) rolls down. Why is this happening to me!!!! Am I cursed? Any help would be appreciated BTW...Happy Halloween!
Old Oct 31, 2008 | 08:29 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You might try re-programming it - the instructions are on their web site.....
http://www.topdowntech.com/wvc5Documentation.html
Old Oct 31, 2008 | 08:50 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
This may be a stupid idea, but have you tried unplugging it and then plugging it back in?
Old Oct 31, 2008 | 08:57 PM
Scriz's Avatar
Scriz
It could be the dreaded window relay problem also. Does the window roll down when you use the door switch? Otherwise, I would just reprogram like the others have suggested.
Chris
Old Oct 31, 2008 | 10:55 PM
homewrecker
It's never too stupid when it comes to me...I will give that a try too
Old Oct 31, 2008 | 10:56 PM
homewrecker
If all else fails I will try that link out. Thank you for always helping out the family
Old Oct 31, 2008 | 10:58 PM
homewrecker
Chris
Both windows roll up and down normally. Just doesn't work when I use the fob. I will try to reprogram if all else fails. I'm at the firehouse looking at the clock to like a schhol boy...and i got 5 minutes more. Thanks for helping!
Old Oct 31, 2008 | 11:14 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I wold try to re-calibrate the fob first, battery may be low. I would then pull and reprogram the WValet, and reset according to your needs.
Old Oct 31, 2008 | 11:15 PM
rws.1's Avatar
rws.1
that suggests the relay in the door contorl module is the issue.
Old Oct 31, 2008 | 11:16 PM
BOTYNV1's Avatar
BOTYNV1
If the windows roll up and down normally, w/out fob your battery(in FOB) may be done.
Old Oct 31, 2008 | 11:22 PM
slvrzo6's Avatar
slvrzo6
Happy Holloween Homewrecker!! Hope you get it fixed!
I can't stand it when something is broken on my Z!
Old Nov 2, 2008 | 05:55 PM
TallCorvetteBlonde's Avatar
TallCorvetteBlonde
Default Hmmmmm
Now I know that question wasn't directed toward my mechanically inept butt!! hehehe
Old Nov 2, 2008 | 06:12 PM
homewrecker
To my forum brothers and firefighting sister...the problem is fixed. A few whacks of the hammer on the window motor will go a long way....temporarily...thanks eveyone. Have a great weekend!
To Window Valet Problem! there goes my weekend!!
