Removing Stuck-on Chrome Trim
Old Nov 1, 2008 | 05:18 PM
akriggm's Avatar
akriggm
Default Removing Stuck-on Chrome Trim
I'm looking at a C5 that has had aftermarket rear chrome letteing, taillight and side marker trim added and it would have to go if I buy the car. Has anyone successfully removed these with or w/o damage and if so, how? I did a search and didn't find much......
Enjoy,
akriggm
Old Nov 1, 2008 | 05:36 PM
hotwheels57's Avatar
hotwheels57
An application of heat and dental floss (or fine fishing line) will remove almost anything that is stuck on with adhesive. Then you can use GOOGONE, 3M Adhesive Remover, denatured alcohol or similar to remove any residual adhesive.
Old Nov 1, 2008 | 06:26 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Rotary Sander with 40 grit
Old Nov 1, 2008 | 07:02 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Takes too long.
This is quicker:
Old Nov 1, 2008 | 07:38 PM
dobewillie's Avatar
dobewillie
steam and goo bee gone
Old Nov 1, 2008 | 09:52 PM
Jet-Jock's Avatar
Jet-Jock
Old Nov 1, 2008 | 11:39 PM
itzza427's Avatar
itzza427
Just to be clear ,,,,Hair dryer!!!
Old Nov 2, 2008 | 07:23 AM
travelingypsye's Avatar
travelingypsye
I used 3-m glue remover. You cn get it at most major auto stores & it works well. Now don't destroy the chrome, I might want it.........I love chrome.........then again I am old.
Old Nov 2, 2008 | 07:50 AM
RSchleder's Avatar
RSchleder
Default Letters?
I understand the chrome taillite bezels, etc, but why the chrome CORVETTE letters--they look GREAT!
Old Nov 2, 2008 | 08:05 AM
Jet-Jock's Avatar
Jet-Jock
Heat from something like a hair drier is what the factory recommends when removing the emblem.
Old Nov 2, 2008 | 09:52 AM
jrose7004's Avatar
jrose7004
Those are my thoughts exactly!
Old Nov 2, 2008 | 12:04 PM
Jet-Jock's Avatar
Jet-Jock
I agree with the OP. I don't like those letters in the brand indentations, or that other nonsense for that matter. I like it the way Chevy designers and engineers designed and created it.
Old Nov 2, 2008 | 12:07 PM
akriggm's Avatar
akriggm
I suspect it's a case of "to each, his own". I have never really been into BLING, so I would probably want to remove them. I just wouldn't want to do any damage to the original paint/clearcoat in the process!!
Thanks all,
akriggm
Old Nov 2, 2008 | 12:18 PM
Jet-Jock's Avatar
Jet-Jock
That is why you use the factory recommended procedure for removing the emblems which use adhesive tape, heat them up and remove them. Then use a paint safe adhesive remover to take off the remaining material.
To Removing Stuck-on Chrome Trim
