Transmissions?
Old Nov 2, 2008 | 11:37 AM
Nver2loud's Avatar
Nver2loud
Default Transmissions?
Will a m6 from a c6 work in a c5? Are they physically the same dimension, same shaft sizes, etc? What about sensors such as skip shift and speedo?
Thanks!!!
Old Nov 2, 2008 | 11:57 AM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
Hmm good question.
Whats wrong with a stock MN6?
They have a C6 Z51 shifter with either shorter throws or different gearing to make it work...
Old Nov 3, 2008 | 12:52 PM
Nver2loud's Avatar
Nver2loud
Mine has some 2nd gear issues, not to mention what else, the clutch is also on its way so i am replacing everything. I saw for sale a 07 Z51 m6 with 17k miles for 1100 bucks, so its almost cheaper than any c5 tranny i have seen...well, for the miles anyway
Old Nov 3, 2008 | 02:02 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
Thanks!!!
^^I do not believe a C6 tranny will work. If you PM (private message) Rodney@RPM transmissions I am sure he can give you a definitive answer.
Old Nov 4, 2008 | 03:36 PM
Nver2loud's Avatar
Nver2loud
anybody know his screen name?
Old Nov 5, 2008 | 06:51 PM
Independent1
St. Jude Donor '08
^^Here you go.
http://forums.corvetteforum.com/member.php?u=19925
To Transmissions?
