[Z06] How does this set up sound?
Old Nov 6, 2008 | 12:10 PM
sublime1996525's Avatar
sublime1996525
Default How does this set up sound?
Ok here is the setup I'm planning on putting in my car. Already have the heads everything else is the plan. If anyone has any other ideas please chime in. Already have LT's and intake.
TFS 215cc milled down to 59cc
XE-R 232/243 cam
LS2 timing chain
hi-vo oil pump
25
p
7.500 pushrods
new springs .660 lift and ti retainers
LS7 lifters
42# injectors
new guide trays
centerforce spec 2+ clutch.
So what do you guys think? Any suggestions?
Old Nov 6, 2008 | 03:43 PM
zeevette's Avatar
zeevette
IF you plan on using GM MLS gaskets, your C.R. is going to be about 11.4:1. Assuming CA. 91 oct., be sure about your tune before hard running on hot days. Sounds like a killer setup, but then I'm biased.
Old Nov 6, 2008 | 03:59 PM
sublime1996525
Yeah I came up with the same thing, I've talked to a few different tuners about it and they said I should be ok. I'm planning on going with a .054" gasket to keep the dcr below 8.5
Old Nov 6, 2008 | 06:50 PM
zeevette's Avatar
zeevette
Just for comparison's case, mine are @ 61cc, and we have 92 octane here in WA. So far the tuner has said no KR, but when I tried to pin him down regarding spark advance, he wouldn't give me a definative answer. I was thinking, if I had to do it again, I'd go for a little more compression. With my cam, my SCR is 10.95:1, and DCR is 8.6. No pinging on even very hot days.
To How does this set up sound?
