Royal Purple Replacement
Old Nov 7, 2008 | 12:45 PM
mmartinez's Avatar
mmartinez
Default Royal Purple Replacement
Am going to replace transmission and rear diff oil with Royal Purple and wondering how much I would need to buy to take to Quick Lube and have them change it out. Thanks Marty
Old Nov 7, 2008 | 01:10 PM
vettelover84's Avatar
vettelover84
auto or 6-speed?
my Z took 1 gallon in the trans(actually a little over 3 quaters), and 2 quarts in the diff.
Old Nov 7, 2008 | 01:12 PM
VetteHunting's Avatar
VetteHunting
All I have to add to this is I would never take my car to a damned quick lube.
Old Nov 7, 2008 | 01:14 PM
Mad Dog Peter's Avatar
Mad Dog Peter
Find yourself a local performance shop and have them do it. Mine took about 3 bottles of the stuff, little over 3. Clutch feels super smooth now, but stick is still pretty notchy--in fact it feels tighter than before, but I have not had any slipping gears...
Old Nov 7, 2008 | 01:20 PM
PETE O.'s Avatar
PETE O.
Two quarts in the differential. It calls for 1.69 plus 4 oz of addidtive. that comes to pretty close to 2 qts. Don't know about the trany?
GreenDream's Avatar
GreenDream
Doing mine tomorrow. Just picked up 4 quarts at Advanced Auto. $15.45 a quart was a shocker... You will use 3.7 quarts
Old Nov 7, 2008 | 01:48 PM
mmartinez's Avatar
mmartinez
Thanks for the replys, I forget that not all Corvettes come with a six speed manuel transmission"6M", only reason I mentioned Quick Lube was I do not have the right equipment to lift my C5, again thanks for all the quick replys. Marty
Old Nov 7, 2008 | 03:10 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Stick with GM Fluids on the Tranny and Rear End ! !
Old Nov 7, 2008 | 05:27 PM
Black Out's Avatar
Black Out
How many miles are you guys at that your doing the tranny and diff. change?
Old Nov 7, 2008 | 05:39 PM
Shortimer's Avatar
Shortimer
If you're going off the GM lubs be sure the new stuff meets the GM specs.
Old Nov 7, 2008 | 08:20 PM
dobewillie's Avatar
dobewillie
keep both eyes open when work is being done good luck
Old Nov 12, 2008 | 11:55 AM
GreenDream's Avatar
GreenDream
I had just hit 70K.
Old Nov 12, 2008 | 04:49 PM
bucwheat's Avatar
bucwheat
Quick lube won't change your Trans fluid in a C-5, at least not around the Augusta area.
Old Nov 12, 2008 | 09:07 PM
pikerunner's Avatar
pikerunner
I also used Royal Purple, with good results.
I also agree with the comment on the quick lubes, nobody will care more about the job than yourself.
Good luck.
Old Nov 12, 2008 | 09:15 PM
BitViper's Avatar
BitViper
Question...
Ive always been under the impression that you could not "mix" tranny fluids..and theat you had to "flush" the tranny when you went to a diffrent fluid
To Royal Purple Replacement
