[Z06] Peeling Center Caps
Old Nov 8, 2008 | 03:04 PM
zee sting's Avatar
zee sting
Default Peeling Center Caps
My 03 Z06's caps are beginning to peel the gray. Does anyone have the paint color? I am not sure if I want to touch them up or just purchase a new set. When will GM learn that paint does not adhere to plastic well...
Old Nov 8, 2008 | 11:40 PM
meldog21's Avatar
meldog21
Just get new(used) caps. I'm sure you can get some cheap. I have extras and I'm sure I'm not the only one. I'll sell you mine. Make me an offer.
Dog
Old Nov 9, 2008 | 08:13 AM
zee sting's Avatar
zee sting
Dog
Without insulting you, I have no idea what they go for. I am interested, what do you waht for them? I need two.
Old Nov 9, 2008 | 02:31 PM
buckster's Avatar
buckster
Site for paint codes http://www.corvettepaintcodes.com/
Old Nov 9, 2008 | 11:35 PM
TEXHAWK0's Avatar
TEXHAWK0
I bought a perfect set of replacement caps off of the "auction site" for $20. I think they would cost at least $20 each if you order them new.
Old Nov 10, 2008 | 07:37 AM
hpfiend's Avatar
hpfiend
Goto NAPA and have them mix up some
WA 9789 that is the paint code for the 02-04 Z06 non-chrome wheels
My local NAPA will make a pint at a time for about 27.00 and you have to buy some clearcoat as well for 7.00
I haven't done this yet but plan to soon.
Old Nov 10, 2008 | 05:27 PM
Atok's Avatar
Atok
Yep, that's what I did as well.
I used a sandblaster to remove all the paint from all my caps. Painted them with a primer/filler and sanded smooth with 400 grit. Finally I gave them a couple coats of WA9789 but I used enamel instead of base/clear. After the paint cured I used a fine brush and some red enamel to re-paint the logos in the center. They look like new now. Pretty inexpensive fix, just a little work.
Old Nov 10, 2008 | 06:41 PM
guitar420911's Avatar
guitar420911
I'm also interested in where I can get a replacement for less than $40 a cap.
To Peeling Center Caps
