[Z06] VR Power Duct Install
Old Nov 8, 2008 | 03:47 PM
dbaker's Avatar
dbaker
Default VR Power Duct Install
Good instruction came with the kit.The couplers were a VERY tight fit,but a little vaseline on the edges made the slide easier.While I was at it,went ahead and cleaned up the MAF & TB.
Good transaction with RPI on this.10% Disc with fairly quick ship.
Unit looks good with the VR system.I didn't notice any power increase,but maybe at higher speeds.My guess 1-4 HP gain.
\db2
Carolina
Old Nov 8, 2008 | 10:41 PM
MPM IV's Avatar
MPM IV
Looks good . I just found out it exsist and am looking forward to getting one.
Old Nov 10, 2008 | 05:46 PM
madman91's Avatar
madman91
thanks for the write up, i love mine!
Old Nov 10, 2008 | 06:13 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
I have been tossing around getting the VR. Just how hard was the installation? Yours looks great.
Old Nov 10, 2008 | 06:58 PM
ssdeuce's Avatar
ssdeuce
I'm very happy with mine also.
Old Nov 10, 2008 | 07:34 PM
dbaker's Avatar
dbaker
The install was VERY easy.It would have taken about 20 min,but I took the extra time to clean the MAF & TBody.
It attached to my VR intake system with no cutting.
I'm sure the 2 VR products work better together than the VR intake and the old stock duct did.
\db2
Carolina
Old Nov 11, 2008 | 10:19 AM
QUIKSILVERZ's Avatar
QUIKSILVERZ
the vararam cai is not a hard install it just takes some time. really it just is a lot of removing of parts so you can get the intake tubes installed and putting everything back together. It will take a couple of hours. As for the inlet tube above it should be a very easy install.
Old Nov 11, 2008 | 09:16 PM
TransAm2002's Avatar
TransAm2002
Easy install after I filed down the inside of the duct to get the maf to fit. Not happy about that, but at least it is on now.
Old Nov 11, 2008 | 09:57 PM
user_name's Avatar
user_name
I have assembled mine with it off the car, but I haven't put it on yet. I am doing a FAST swap at the same time. Should be done later this week.
The stock 85mm MAF has a little notch on the side that gets in the way, but there is still plenty of room to attach the coupler and clamp it down for a good seal.
Old Nov 12, 2008 | 03:32 AM
QUIKSILVERZ
ordered mine this morning.
Old Nov 13, 2008 | 10:33 PM
user_name's Avatar
user_name
Well, I got mine installed. I did a FAST90 intake with an ls2 TB at the same time. I wasn't real happy with the fitting of the coupler from the MAF to the TB. After looking at the pic in the first post I think it is due to the MAF and/or intake though. It seems to point a little bit upward. I need a flexible or bent coupler. I got it to all seal as is, but it doesn't look just right.
Old Nov 13, 2008 | 10:40 PM
TransAm2002
I hear you. My maf was a pain to get to fit. I hope I never have to take it off the power duct because I am sure either the duct or the maf is going to break. It is way to tight.
Old Nov 14, 2008 | 10:46 PM
QUIKSILVERZ
installed mine today. Very easy install. my maf and couplers fit great. the maf would just slide out if not for the clamps. did not get a chance to drive the car after the install though. I did not get it for any power increase. i wanted to see if it would help with some issues i started having after my vararam cai install. the couplers seem to seel well and the duct does look great with the cai. look forward to driving the car post install.
Old Nov 23, 2008 | 06:16 PM
user_name's Avatar
user_name
You can see here how mine fit with the FAST90/LS2 TB combo. Also notice the fitting I had to put in there for a fresh air source since the ls2 TB did not have one, and I am still using a closed PCV system.
To VR Power Duct Install
