Tire Size Question
Old Nov 8, 2008 | 08:25 PM
crazychucky8's Avatar
crazychucky8
Default Tire Size Question
I bought my Z about 4 months ago and need to replace the tires. I have a set of tires in my garage on Vette rims. The fronts are 245/45/17 and the rears are 285/35/18. If I use these tires to keep saving up for the OEM size, will the Traction system function properly or am I going to get errors?
Thanks for your help!
Old Nov 8, 2008 | 09:18 PM
8VETTE7's Avatar
8VETTE7
The rolling diameter of the 245/45/17 is about 25.7 while the rolling diameter of the 285/35/18 is about 26.0 inches. These numbers are for new tires. Since rears wear faster than do fronts ( I wonder why that is? ) the differential in rolling diameters is probably less than 0.3 inches on the tires you have. The recommended differential in rolling diameters is about 0.5 inches for new tires so using the tires you have would probably put you on the edge of causing the traction control to start doing its thing. You could turn off the traction control but I do not recommend you do that especially if you would be driving the car in winter condtions.
Old Nov 8, 2008 | 11:45 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
you dont want to put 245 on the front.
You will have horrible oversteer
To Tire Size Question
