Replacement door speakers
Old Nov 9, 2008 | 08:16 PM
CLEAR's Avatar
CLEAR
Default Replacement door speakers
Can I just replace the door speakers without anything special if my car has bose? Would new speakers be plug and play or do I need something else to make aftermarket speakers work with the stock HU?
Old Nov 9, 2008 | 09:45 PM
4 KRUSIN's Avatar
4 KRUSIN
I'm not an expert, but I suggest you check out the Audio/Electronics page under General Corvette.
Dave
Old Nov 9, 2008 | 10:13 PM
MagRedConv's Avatar
MagRedConv
Check out the Audio/Electronics section. It's dedicated to, well, audio & Electronics.
Old Nov 9, 2008 | 10:29 PM
c5blkvetteguy's Avatar
c5blkvetteguy
If you have bose you have to replace with bose, or change alot. Bose is not aftermarker friendly! Check e-bay, I know there are factory speakers there.
Old Nov 9, 2008 | 10:43 PM
kg54trains's Avatar
kg54trains
The systems operations are different. Most or all after market speakers are 8 ohms and Bose is 4 ohms. Bose can use a smaller amp/power to push their speakers. If you use a 8 ohm speaker you will find that the power/sound generated is weak. You will also need adapters for the leads to the after market speakers.
To Replacement door speakers
