AC question
Old Nov 11, 2008 | 07:00 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
Default AC question
stupid question, here goes everytime i get into the verte and i try to either put the heat on or just simply have the air on, the AC automatically comes on, is that normal?
Old Nov 11, 2008 | 07:41 PM
Chuck A's Avatar
Chuck A
Ttt
Old Nov 11, 2008 | 08:34 PM
Chuck A's Avatar
Chuck A
So i guess it doesnt happen to anyone else, thanks
Old Nov 11, 2008 | 08:42 PM
jraschke11's Avatar
jraschke11
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
I often can't turn the a/c off. I guess it's because whatever you have the temp set at, the computer wants the a/c on to achieve that temperature.
My friend has an older car, and whenever he turns on the heat he always hits the "a/c" button because he says air conditioning means it conditions the air, whether cold or hot.
sneakelman's Avatar
sneakelman
No worries. It's normal for the auto climate. Mine does the same too.
Old Nov 11, 2008 | 09:02 PM
jrose7004's Avatar
jrose7004
Mine does that.
Old Nov 11, 2008 | 09:10 PM
Chuck A's Avatar
Chuck A
Excellent, thanks, i thought it was a defect, thanks again
Old Nov 11, 2008 | 09:11 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
Old Nov 11, 2008 | 10:18 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by jrose7004
Mine does that.
Same here
Old Nov 11, 2008 | 11:02 PM
Robls6's Avatar
Robls6
If you hit the AC button again it will turn the compressor off and just use the fan or the heat depending on your temp. setpoint.
Old Nov 12, 2008 | 01:54 AM
00Corvette's Avatar
00Corvette
Hello,
The reason that your AC turns on every time you start the car is probably because you have memory seating???
IF you do, I'm pretty sure that it memorizes seat position, side mirrors and climate control.
Just a thought,
DZ
Old Nov 12, 2008 | 08:23 AM
poolboy's Avatar
poolboy
This is explained in the ownners manual - net is that when you have the HVAC set to Auto, that enables the defroster which means the AC runs. Change the mode to something that does not have defrost on, then press the AC button and it should turn off. Hope that helps
Old Nov 12, 2008 | 10:07 AM
Chuck A's Avatar
Chuck A
Excellent, and yes i have memeory seating, thanks for the output, and yes i hit it again and the compressor goes off
To AC question
