Sequential Tail Lights
Old Nov 13, 2008 | 02:13 PM
skidmarc's Avatar
skidmarc
Default Sequential Tail Lights
I found two kits. One from Ecklers (just turn signals) and another from Corvette Garage (does brakes and signals). The one from CG looks like a blk box and Ecklers is plug and play. I have the Euro tail lights.....pros, cons and or experience with each? I bought a kit for my C5 back in 2000 but it blinked way too fast.
Thanks for any input!
Old Nov 13, 2008 | 02:33 PM
Bills03Coupe's Avatar
Bills03Coupe
Check out www.webelectricproducts.com, but I'd check to make sure they work with the Euro tailights, as they have the extra bulb for the back up lights. I have their pulsating third brake light, which I'm very pleased with. An easy install (plug and play).
Old Nov 13, 2008 | 03:28 PM
ALLEGRO's Avatar
ALLEGRO
I have these and I am very pleased. It gets a lot of comments due to its uniqueness.
Old Nov 13, 2008 | 05:40 PM
rpm462's Avatar
rpm462
Me too...plus they have a lifetime warranty. I had one go bad about 2 years after I bought them due to some water getting in it and they replaced it without any hassle!
Old Nov 13, 2008 | 07:16 PM
krm_wi_C5's Avatar
krm_wi_C5
I was thinking about these last year, but was told that they do not work well with LED's, I have the Halo's. Does anyone out there know if they will work with the Halo's?
Old Nov 14, 2008 | 12:36 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I got an ebay sequential and had hyper flash with the ebay LED tails. Richards bypass LED flasher harness fixed all that. Since I had the flasher bypass I had to have the Switchback front turn signals. Since the outside was all LED and I fought the crack monkey for a few months my addiction gave way to the interior(freakin monkey). Once the postman shows up with my auto illumination order the interior will be awash in hyper white LEDs.
Anyway if you have an issue with the sequentials hyper flashing with LEDs there is a bypass flasher that's plug and play that will fix the problem. No idea about Euros and sequentials.
Old Nov 14, 2008 | 03:48 AM
JETZ's Avatar
JETZ
No problem with Euros, or pulsating third light.
Old Nov 14, 2008 | 06:13 AM
rws.1's Avatar
rws.1
webelectric
To Sequential Tail Lights
