C5 Ride Height
Old Nov 13, 2008 | 04:54 PM
tom_c5's Avatar
tom_c5
Default C5 Ride Height
My Y2K C5 seems like it's sporting the "4x4" look even more so than other stock C5's. I was wondering if a few of you (w/ no lowering done on the car) could do a quick measurement for me of the distance between the top of the tire and the edge of fender. I am measuring roughly 3.5" front & rear. Thanks
Old Nov 13, 2008 | 05:08 PM
FlyboyZR1's Avatar
FlyboyZR1
Just measured my Y2K and stock ride height is 3" front and rear, not sure why yours would be an extra .5" ... my car is a Z51 if that makes a difference.
Old Nov 13, 2008 | 05:42 PM
dbiddle's Avatar
dbiddle
HI, just went out to see what mine was. And it is a Z51 and its was front and rear 2" frome top of tire to body if this helps you. dbiddle
Old Nov 13, 2008 | 05:44 PM
dbiddle's Avatar
dbiddle
was thinking, Have you changed the tire's?..Just a thought..dbiddle
Old Nov 13, 2008 | 06:05 PM
JEEP/C5's Avatar
JEEP/C5
My 01 z51 was 3.5 inchs in front and 3 in the rear. I recently lowered it all the way on stock bolts and now it is 2.25 front and 2 rear (which looks perfect IMO with my wide tires.
Old Nov 13, 2008 | 06:32 PM
killain's Avatar
killain
Oldtimer
My completely stock 2003 is just a little under 3"
Old Nov 13, 2008 | 06:35 PM
Bill Dearborn's Avatar
Bill Dearborn
Ride height is measured from the frame to the ground. Fender heights will vary.
Bill
Old Nov 13, 2008 | 07:43 PM
tom_c5's Avatar
tom_c5
I guess I do have a 4x4 The only thing i can think of was that it changed after I installed the C6Z06 shocks about a month ago. i should have done an actual measurment before the shock change-out. If I remember right the new C6Z06's were a bit longer than the originals. I wonder if the ride height will be able to lower down enough when I try to lower it on the stock bolts. we shall see here in a few weeks. I will keep you posted.
Old Nov 13, 2008 | 08:13 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Same here for my '03. I would like it a little lower but with the speed bumps in my neighborhood and the fact that I already scrape coming into my driveway it will have to stay stock.
Old Nov 13, 2008 | 08:44 PM
91LSMAN's Avatar
91LSMAN
I remember reading the the C6Z06 shocks can actually raise the car a bit when they are installed.
Old Nov 13, 2008 | 09:24 PM
robsc501's Avatar
robsc501
Hi There:
I just measured my stock 01 3" front & rear both sides.
robsc501
Old Nov 13, 2008 | 09:57 PM
Dominic Toretto's Avatar
Dominic Toretto
Let us know how it turns out.
-Alex
To C5 Ride Height
