Demon Pin-ARGH!!!
Old Nov 14, 2008 | 08:59 AM
silverbird's Avatar
silverbird
St. Jude Donor '08
Default Demon Pin-ARGH!!!
It's over!
I tried all the methods on the forum for the demon pin/shift **** removal. I now have a demon pin with chamfered corners due to the channel locks slipping off.
There is no way the pin is getting pulled off now!
Looks like my only option to remove the **** is hack saw the **** into pieces.
Best approach at the hack saw method?
Anyone else have to do this?
Any other ideas out there?
Thanks,
Silverbird
Old Nov 14, 2008 | 09:07 AM
rws.1's Avatar
rws.1
channel locks with jaws on front and rear of the demon key
tap sharply on right side of vice grips with hammer as you wiggle the vice grips front to back and pull up (like a dentist pulling a tooth)
Old Nov 14, 2008 | 09:27 AM
talon104's Avatar
talon104
I'd Have to agree try rws.1 's method, worked for me (pretty easily actually) just beware when the demon key does let go! think i bounced the vise grips off the edge of the molding on the roof pnl, no problems.
Old Nov 14, 2008 | 09:30 AM
Robls6's Avatar
Robls6
It's really not hard to remove. Clamp a good pair of vice grips tightly on the pin, then clamp another pair perpendicularly to the first pair and tap directly up on the second pair of vice grips with a hammer. Mine came out with one really light tap.
Old Nov 14, 2008 | 09:40 AM
SearayC5's Avatar
SearayC5
Lock channel locks onto the demon key. Stick a screw driver through the gap on the closed end of the demon key. Place a small piece of wood on the backside of the demon key. Then use the screw driver to pry up the demon key. This is the only thing that worked for me. Good luck.
Old Nov 14, 2008 | 09:46 AM
FLATOUT's Avatar
FLATOUT
Temporary Hold
From: www.modular-concept.com www.flatoutimaging.com
I boogered mine up like the the first time, but once it comes off it will make sense to you how it works.
I went to the Chevy dealer and bought a new one, and now that I understand it, I have taken it off many, many times, and it is cake!
No worries buddy
Andy Wheeler
Old Nov 14, 2008 | 10:47 AM
GreenDream's Avatar
GreenDream
Squirt a little WD-40 around it and I had my best luck using a paint can openner to pry with rather than a screwdriver. Gives you better leverage without damaging the leather.
To Demon Pin-ARGH!!!
