[Z06] CAGS Not Locking Out 2nd
Old Nov 15, 2008 | 11:54 AM
nmaier88's Avatar
nmaier88
Default CAGS Not Locking Out 2nd
I bought a 2004 Z06 a few weeks ago and I noticed that CAGS is not locking out 2nd. Under light acceleration in 1st I get the shift 1 to 4 light, but I can easily just put it right into 2nd. The previous and only owner said he did not put a CAGS bypass on the car. Is there any way I can check to see if the CAGS bypass is installed? With the CAGS bypass will the shift 1 to 4 light still come on? Thanks,
Nathan
Old Nov 15, 2008 | 11:59 AM
Warped Sol's Avatar
Warped Sol
Yes, the light will still come on with the bypass installed. A visual inspection of the transmission will reveal if it was done. Curious about the prior owner saying it wasn't installed.
Old Nov 15, 2008 | 12:07 PM
nmaier88's Avatar
nmaier88
As am I. What exactly should I look at to see if the CAGS eleminator has been installed? The car is pretty low, and I can barely stick my head under there as it is. Any pictures to point me in the right direction as to where to look?
Old Nov 15, 2008 | 12:10 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Your car has a CAGS bypass plugged into the transmission.
Old Nov 15, 2008 | 12:20 PM
bobdobb's Avatar
bobdobb
You will have to jack up the car your head is as fat as mine Look on the drivers side of the tans and there should be a plug with nothing plugged into it. There shouls be a plug on part of the harness near by that a dummy plug on it. It should be zip tied to a tab on the trans next to the spot where it should plug in. Hope this helps. It does sound like it has one on it.
Old Nov 15, 2008 | 01:22 PM
lbarnard's Avatar
lbarnard
If you've tuned the car the tuner can program that out so the light won't come on.
Old Nov 15, 2008 | 08:21 PM
bobdobb's Avatar
bobdobb
Nice dog pic in the avitar
Old Nov 15, 2008 | 09:28 PM
bob guzzy's Avatar
bob guzzy
I have the skip shift eliminator, but never saw the shift light and I know it's there because I put it on.
Old Nov 16, 2008 | 08:40 AM
lbarnard's Avatar
lbarnard
Thanks bobdobb
Old Nov 24, 2008 | 01:03 PM
cuspid's Avatar
cuspid
I had one installed that stopped working after 2 years. I took it apart and there was no resistor in it, just a plug of silicone. I soldered a resistor in place and put it back together and working fine now. This is one I had bought.
To CAGS Not Locking Out 2nd
