(video) Funny Headlight Problem
Old Nov 16, 2008 | 05:59 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Default (video) Funny Headlight Problem
Edit: A nice response on how to fix this issue with pics is in post #26.
Shot this video of a friends car this morning.
Old Nov 16, 2008 | 06:04 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Drive a stake through its heart!
John@autobuffs.net
Auto Buffs LLC.
2 Kerry Ct,; Suite E
Southampton, NJ 08088
609-859-0900
www.autobuffs.net
Authorized IFORGED Dealer
Authorized East Coast Supercharging Dealer
Authorized TireRack Dealer
Custom Painting & Airbrushing
Pinstriping
Custom Detailing
Car Audio
Mobile Electronics & Video
Remote Car Starters / Alarms
Old Nov 16, 2008 | 07:29 PM
Turbopower87's Avatar
Turbopower87
haha that's pretty funny, sorry I can't help though
Old Nov 16, 2008 | 07:31 PM
91LSMAN's Avatar
91LSMAN
The car likes the camera man-it's winking.
Old Nov 16, 2008 | 07:33 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
He may get lucky or get bitch slapped big time
Old Nov 16, 2008 | 07:47 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Stop drinking?? I love the intro pic
Old Nov 16, 2008 | 07:57 PM
1sickz51vette's Avatar
1sickz51vette
You have to shim the bolts with washers where the headlight motor mounts.
Old Nov 16, 2008 | 07:59 PM
hdog's Avatar
hdog
The head light control module is bad. I had the same problem earlier this year and it burned up my head light motor. Thank GOD for my warranty.
Old Nov 16, 2008 | 08:36 PM
1sickz51vette
I say its the motor needs to be shimmed still, i had the same problem with mine!
Old Nov 16, 2008 | 08:42 PM
Jet-Jock's Avatar
Jet-Jock
Old Nov 16, 2008 | 08:47 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
There is nothing wrong with the car, that is a canadian turn signal
Old Nov 16, 2008 | 09:37 PM
hawaiiC5's Avatar
hawaiiC5
St. Jude Donor '09
Old Nov 16, 2008 | 09:51 PM
Choreo's Avatar
Choreo
I am guessing alcohol in the washer fluid
Old Nov 16, 2008 | 10:01 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The most likely problem is the headlight lifting arm is sliding off the bolt where it's not hitting the limiter. There's a 10mm bolt that usually holds the arm tight on the bolt. (see picture) This bolt is either loose or has fallen off. When you put it back on, I'd suggest throwing on a lock washer as well.
Here's how to get to it:
1) first pop the hood and manually raise the headlight by twisting the cap on the motor until it's completely up. Then lower the hood and remove the 3 phillips screws on the bucket trim:
2) Next remove the 4 torx-15 screws the hold the cover on:
3) next remove the 8mm bolt and torx 20 screws that are the hinge of the headlight frame: you'll need an open end 8mm wrench (adjustables, box-ends and pliers won't fit) Once these are out, gently lower the frame and reflector into the headlight cavity to access the problem area
4) and here's the problem spot: This is a 10mm bolt (if it's still there)
Quick fix shouldn't take more than 15 minutes.
now that's freaking funny
Old Nov 16, 2008 | 10:09 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Old Nov 16, 2008 | 10:12 PM
red97vette's Avatar
red97vette
hahahhaa
Old Nov 16, 2008 | 10:13 PM
MikeC4's Avatar
MikeC4
Larry,
Thanks for posting this dude!! Looks like some good advice given on the fix.
Thanks "TheRadioFlyer", especially for the detail and pics. Greatly appreciated.
Funny thing is, if this light actually closed after the "winking" session, I would probably let it go, as it always made me laugh flopping up and down like that.
Thanks to all......(did the Canadians really invent this?)
To (video) Funny Headlight Problem
Old Nov 16, 2008 | 10:16 PM
Cozmo's Avatar
Cozmo
RadioFlyer,
thanks for the info and the great write up.
Old Nov 17, 2008 | 12:15 AM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
Been there and have done this fix. All it takes are 3 washers as stated above and place these between the motor and where it mounts to the bracket. Mine is all done winking, EH.
Old Nov 17, 2008 | 02:43 AM
Birdman's Avatar
Birdman
Pretty funny at the beginning, lol.
