Damn electrical gremlin
Old Nov 17, 2008 | 04:09 AM
RedRckC5's Avatar
RedRckC5
Default Damn electrical gremlin
Coming home from my brother's house last night, my headlight started dimming when I turn the turn signal. Also, the radio lights and HVAC also started to dim in and out. I searched the forum and found out many cause. Main thing is the battery. Just got the damn thing 10 months ago! Any other suggestions?
Old Nov 17, 2008 | 08:00 AM
Oldvetter's Avatar
Oldvetter
Check if your battery terminals are tight, if you can rotate them by hand, they are too loose. Be careful, if you tighthen them too tight, you can cause battery to leak acid.
Then check the nuts on the starter for tightness.
Good luck.
Old Nov 17, 2008 | 09:39 AM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Good luck.
Check and clean ALL the grounds on the car!
Do a search in the tech forum for locations.
Old Nov 17, 2008 | 09:46 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
possible a bad ground!
Old Nov 17, 2008 | 11:28 AM
poolboy's Avatar
poolboy
if this is happening while the car is running, isn't it the alternator that is suppling power at that point?
Old Nov 17, 2008 | 11:55 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Bad connections can prevent a good battery from getting fully charged and delivering full power. As mentioned in other posts first clean and tighten the battery connections and clean the grounds. Check the battery voltage with the engine off. it should be between 11.5 to 13.0 volts. With the engine up to operating temperature turn on the ac and headlights. The battery voltage should be between 12 and 16 volts. If your readings are not in these ranges have the battery and alternator checked.
Old Nov 17, 2008 | 05:09 PM
RedRckC5's Avatar
RedRckC5
Thanks! I'll check the ground and connection. It was worse when I turned the ac on while driving. I just noticed it because it was at night and my headlight started dimming when I hit my turn signal.
Old Nov 17, 2008 | 10:30 PM
bgreen83's Avatar
bgreen83
Hope you get it fixed brah. Maybe you can ask your bro to borrow the ZR1 while you get your car fixed lol.
Old Nov 17, 2008 | 10:41 PM
Iwant1too's Avatar
Iwant1too
Default Hope this helps
Here is a link to a VERY useful sticky in C5 Tech.
http://forums.corvetteforum.com/c5-t...tion-long.html
I cleaned the front ground point plugs and it solved my gremlin problem.
In reference to the battery terminals, be careful. I have read some posts where the depth of the threaded holes in some batteries were too short for the cable bolts. The bolts get tight (because they bottom out) but the cables still move (and lose connection).
Good luck.
To Damn electrical gremlin
