[Z06] Antifreeze
Old Nov 18, 2008 | 08:34 PM
61 Silver's Avatar
61 Silver
Default Antifreeze
I purchased a 2003 ZO6 with 14,000 miles in August. I live in Western New York and the winter weather has arrived. I check the Dex-Cool antifreeze last evening to determine the freezing point and it is good to 20 below "0". I have heard that Dex-Cool antifreeze is very corrosive and that many owners have changed to the older type of antifreeze. Are there any members that have changed their antifreeze from the Dex-Cool antifreeze?
Thanks for any advise!
Ray
Old Nov 18, 2008 | 09:07 PM
froggy47's Avatar
froggy47
Ray
It's not corrosive, on the contrary it is longer lasting than the green. I have it in 2 chev's with combined miles of 100k & it's fine.
Old Nov 18, 2008 | 09:14 PM
sothpaw2's Avatar
sothpaw2
How often do you change the green stuff? the Dexcool? I used to think every 3 years but I've pushed that to 4 with my current car with no issues.
Old Nov 19, 2008 | 11:20 AM
froggy47's Avatar
froggy47
Green I used to do 2-3 years,
Orange 4-5 years.
But you still need to LOOK at it & test it (I do annual). Test kit at pep boys etc.
Old Nov 19, 2008 | 07:25 PM
motoman's Avatar
motoman
I heard Dex-Cool is very corrisive. I know cadillac has had problems with dex-cool and intake manifold gaskets failing. Also heard other GM intake gasket problems. I changed the vette after 5 years per my cadillac mechanic friend's advice.
Old Nov 19, 2008 | 08:30 PM
LT1GMC's Avatar
LT1GMC
Thats bull, the problems some had with gaskets was the gaskets problem, not Dexcool. Just changed the Dexcool first time in my 6 yr old '03 Z06, clear as can be. I installed Dexcool in my 92 LT1 Corvette in 1996, just after Dexcool came out. Just changed it for the first time last weekend, clean and no corrosion, 30,000 miles and 12 years in car. Original hoses too, been raced in Silver State Classic 5 times. I gotta say I am pleased with Dexcool.
Old Nov 19, 2008 | 09:19 PM
bobby777's Avatar
bobby777
How true - dont change your coolant--waste of money
Old Nov 20, 2008 | 01:21 PM
dbaker's Avatar
dbaker
As a general rule I change the Anti-freeze every 2 years in all my cars.Probably don't need to,but what the heck....
The others fluids I do this:
Oil & Filter=3k or 3mos
Brake & Clutch Fluid=same as O&F
Trans & Diff fluids=every 12k or once a year
Power Steering=same as Trans/Diff
Fluids are still fairly cheap....Piece of Mind=Priceless
\db2
Carolina
Old Nov 20, 2008 | 05:27 PM
froggy47's Avatar
froggy47
This will be hard to kill off.
Old Nov 20, 2008 | 06:40 PM
briann510's Avatar
briann510
Its friggin antifreeze. Spend $20 a year and change it if there is concern of it being bad over a few years. It ain't rocket science.
I just changed mine after 42K miles and 5 years and it still looked brand new and when I tested for electrolysis it was also fine. I wouldn't have even changed it cept I swapped out the thermostat and lost most of it anyway.
To Antifreeze
