Cd Changer Problem
Old Nov 18, 2008 | 09:46 PM
IDM's Avatar
IDM
Default Cd Changer Problem
Bought a cd changer from a member.
When I plugged it in, it reads error on the headunit and the cd cartridge wont come out.
Any ideas?
Old Nov 18, 2008 | 11:12 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The cartridge is stuck inside...hmmm. Why did the seller, sell it? I'll venture a guess that either there's no power to it or its physically jammed somehow. If you have power there, you're going to have to take it apart and find out what's going on in there.
Old Nov 19, 2008 | 03:36 PM
IDM's Avatar
IDM
theres power to it, wondering if it can be reset or some way to get the magazine out
Old Nov 19, 2008 | 03:51 PM
jrprich's Avatar
jrprich
There is a "reset" button.
As you are looking at the front of the unit, it is a tiny black hole to the far upper left corner. Needs a small pen tip or unfolded paper clip to depress the rubber switch.......make sure your key is ON and the radio is ON
Not sure if this will do what you need though
Old Nov 19, 2008 | 10:12 PM
IDM's Avatar
IDM
hmm any other experiences with this?
thank you to those who have helped already.
Old Nov 20, 2008 | 10:31 AM
IDM's Avatar
IDM
ttt
Old Nov 21, 2008 | 09:50 AM
IDM's Avatar
IDM
ttt
Old Nov 21, 2008 | 03:46 PM
jrprich's Avatar
jrprich
The reset button did not help ?
When you open the changer door, what happens ?
Have you tried pressing down on the cassette with the door open ?
Old Nov 21, 2008 | 09:46 PM
IDM's Avatar
IDM
yeah the magazine wont come out and it says error
ive seen that a lot of these have had problems!
what is the deal with that? another junk piece in the c5
seems like they randomly break used a lot or not
Old Nov 21, 2008 | 09:57 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
Heres what you need to check.
When you Mount the CD Changer if the screws you used to mount it are too long it will interfere with the mechanism.
I suggest you demount it but keep it plugged in. (remove the 4 screws from the mount)
The Cartridge should then pop out.
The Screws to mount it have to be super short for it to work.
Old Nov 21, 2008 | 10:20 PM
IDM's Avatar
IDM
never heard of that, interesting
does this have to have power to it to take the magazine out?
Old Nov 22, 2008 | 11:08 AM
IDM's Avatar
IDM
also has anyone had theirs repaired?
what is the cost?
Old Nov 22, 2008 | 02:22 PM
rkhegler's Avatar
rkhegler
I had this happen to my changer. I took the cover off and was able "dislodge" the stuck CD in the tray. There was enough play in the tray to wiggle it and have the CD fall back into proper place. This problem occurs when you are selecting a CD and then decide to change to a different CD without letting the first one you choose cycle. Be careful if you take the cover off because there are a bunch of little screws and springs that can either fall out or become detached. It was a fairly simple fix. If you decide to take a look at the inside, take the entire player out of the mounting brackets in the trunk without unplugging it. That way you can have someone run through the selections from the dash while you find out which CD is stuck. I am not sure that this will help if the CD is not the issue. Good luck.
Old Nov 22, 2008 | 03:28 PM
dieseldave56's Avatar
dieseldave56
Default CD cycle ..........
That has happened to the wife's CD changer , so now she just lets the CD cycle thru before switching to another selection. I have 5 vehicles that use the remote 12 disc CD changer ( both Delco and Pioneer) with out problem other than installing the CD upside down ( which most eveyone has done) or this particular operating error. ( I keep three changers as spares but have yet to need any of them in 12 years).
Old Nov 22, 2008 | 03:48 PM
HG's Avatar
HG
Just bought a 99 with a 12 CD changer. Do yo leave the CD's in during the winter if you are not driving the car. IF not, can you just leave out the pop out unit. THanks
Old Nov 22, 2008 | 04:11 PM
dieseldave56
Default Extreme measure , but that's me.............
I actually remove the CD changers from my vehicles ( 5) during the winter as it get below minus 20 degrees here at times. I do use dessicant packs and plastic tubs of baking soda placed in the interiors but it so easy just to remove the remote CD changers.
Old Nov 23, 2008 | 10:55 AM
IDM's Avatar
IDM
Is it really needed to do all that stuff for the interior?
what will happen if you dont? why not give some heat to the garage instead?
To Cd Changer Problem
Old Nov 23, 2008 | 12:03 PM
dieseldave56
Default You pay for the heating costs, please......
Well wouldn't that be nice, maybe radiant floor heat as well as A/C but do you know what energy cost to keep two (2) 40x 60 buildings plus the 26x30 garage heated when temps are below freezing more than half the year and as low as -20 often? That is a challenge that I did not have in the SF Bay Area of Kalifornia.
I do a lot of prep for winter for with 40ft motorcoach and all of the storage vehicles. Just keeping battery tenders for all eleven (11) vehicles in storage is enough. Avearge cost just to heat the residence is $680 in the winter ( according to the boss,) , that's roughly ten times the cost when we lived in Kalifornia ( where a winter low night time temperature there is a day time temp high here). It just requires more 'work' to live in the wilderness.
Old Aug 31, 2009 | 04:08 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
hmmm, good info, will try
Old Sep 4, 2009 | 11:17 AM
SteveDoten's Avatar
SteveDoten
if you remove the 6 screws(4 on sides and 2 near conn.) you can release the white lever to get the mag. out
I do not know how to reset the changer to do that on it's own at this pt.
