painted rims?
Old Nov 18, 2008 | 11:52 PM
Evers98's Avatar
Evers98
Default painted rims?
has anybody painted their stock 5 spoke rims themselves? anybody painted them with a spray can?
Old Nov 19, 2008 | 08:24 AM
cnw's Avatar
cnw
I have. Black powdercoated. Yellow spray can.
Craig
Old Nov 19, 2008 | 08:46 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
I painted my powder coated Mallett wheels with spray cans. After a thorough cleaning and a light sanding they received three coats of color followed by three coats of clear.
Old Nov 19, 2008 | 10:20 AM
yamahajo's Avatar
yamahajo
Cruise-In 9-10-11 Veteran
St. Jude Donor '08-'09-'10,-'13
I believe in the Beer Fairy
I know I woudn't try it. I've seen a few go horribly wrong....
Old Nov 19, 2008 | 10:28 AM
topkart43's Avatar
topkart43
I painted mine with the duplicolor satin black. Turned out great!!! i get compliments all the time on my wheels. Many people think i had my wheels powder coated. You just have to prep your wheels very well and clean them. I did alot of research before i actually painted them. If you do do it don't rush it take your time. This first time i did it on another car we put the wheels on to soon and we had to touch up the wheels later on. Duplicolor recommends letting your wheels sit for a couple days. I also used the duplicolor clear coat and it really made the wheels hold up better through rain and from brake dust. If have any questions let me know
Old Nov 19, 2008 | 11:11 AM
iflex2fitness's Avatar
iflex2fitness
What are the step by step instructions?
Products used for cleaning, sand paper, etc.
Old Nov 19, 2008 | 11:15 AM
bucwheat's Avatar
bucwheat
Your outcome depends on good prep work and quality products
Old Nov 19, 2008 | 02:21 PM
Evers98's Avatar
Evers98
what are the prep steps?
Old Nov 19, 2008 | 03:29 PM
Evers98's Avatar
Evers98
bump
Old Nov 19, 2008 | 04:18 PM
BigSexy181971's Avatar
BigSexy181971
I painted mine and a couple of other sets for people and they turn out better and better each time. All I did was...
1. wash them well with soupy water.
2. I used a green brillo pad because they are very flexible and last longer then sand paper for scuffing purposes.
3. Scuff the rims till you see a the shine dissapear.
4. Wash them again with soupy water.
5. I have some of those 500 watt very bright yellow shop lights, so I placed the rims on 1 gallon paint cans so they were off the floor (easier on the back) and placed the lights about 12" or less away from them to heat up the rims.
6. Always paint the backside and the part you will not see first with your 3-4 coats, then do the face starting at the center, move to the inside of each spoke, next the face, and lastly the outer ring.
7. I use 3-4 coats of paint and at least 4-5 coats (1 can) of clear making the last one nice and heavy. DO NOT PUT THE CLEAR ON TOO HEAVY OR IT WILL CRACK. Don's ask!! The heat from the lamp helps bake the paint and clear on very quickly.
I USE THE LAMPS!! It is the only way to go with using spray cans.
Good luck.
Old Nov 19, 2008 | 07:50 PM
Evers98's Avatar
Evers98
anybody just spry flat black paint and no clear coat?
Old Nov 19, 2008 | 08:03 PM
Spoon83's Avatar
Spoon83
I did my old Y2K % spokes with Dupli-Color Wheel Paint (Flat Black). Used blue painters tape to mask off the areas and put index cards in between the wheel and tire to keep paint off the Tire itself. Then just scuffed the clear off with green scotch brite pads. wiped it with rubbing alcohol and sprayed. The good thing about that paint is that it does not require a coat of primer because it pretty thick, does not run and is rated to 500 degrees.
Old Nov 19, 2008 | 08:09 PM
Evers98's Avatar
Evers98
ok now would it b a good idea to scuff with some light sand paper?
Old Nov 19, 2008 | 10:56 PM
Evers98's Avatar
Evers98
anybody?
Old Nov 20, 2008 | 01:10 PM
Good info. Take one of your wheels and give it a try. If it comes out to your liking, great. If not, you can always get it professionally done.
Old Nov 20, 2008 | 08:38 PM
Evers98's Avatar
Evers98
bump
Old Nov 20, 2008 | 09:26 PM
pro1955's Avatar
pro1955
I scuffed my silver thin spokes with a scotch brite pad, painted pass. side gunmetal gray, drivers side satin black. The real trick is to not get in a hurry, don't put paint on too fast. It looks great, I liked the gray color better for my car.
To painted rims?
Old Nov 20, 2008 | 09:42 PM
Evers98's Avatar
Evers98
sounds good looking forward to doing it myself. i think im going to go with satin black and see how it goes
Old Nov 21, 2008 | 08:09 AM
BigSexy181971
Yes some sand paper is fine. I did that on the first set but realized it was a lot more work then just the green pad.
Old Nov 21, 2008 | 11:31 AM
Evers98's Avatar
Evers98
what do you mean alot more work?
