washing engine bay ????
Old Nov 21, 2008 | 03:37 AM
luckyirishguy's Avatar
luckyirishguy
Default washing engine bay ????
do you guys just use a a spray and wipe?blast with a pressure washer?
and if a pressure washer....do you cover any parts????
or any other methods??
Old Nov 21, 2008 | 05:14 AM
c5z06vette's Avatar
c5z06vette
Good question,
Old Nov 21, 2008 | 05:26 AM
paullywalnuts's Avatar
paullywalnuts
My engine bay has always been pretty clean since I got it. But I'll use an old paint brush to loosen the sand and dust..then blow it out with compressed air. For deep down inside near the frame I'll just spray some degreaser in there and reach to wipe it with a cloth. Then use a spray bottle to dilute the residual degreaser so theres no streaks and wipe dry again..I'm a bit weary about using my pressure washer in there..but to each his own I guess.
Old Nov 21, 2008 | 07:29 AM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
Never use a pressure washer on newer vehicles. There are too many wire connectors and parts that should not be exposed to lots of water. Use the wipe and dry methods even if it takes three times as long. Otherwise you could end up with problems.
Old Nov 21, 2008 | 08:26 AM
bucwheat's Avatar
bucwheat
I have sprayed my engine with simple green and pressure washed it with no problems,if you have an open element air filter ,cover if ,that's all.These engines are not sponges,don't worry about water.
Old Nov 21, 2008 | 09:08 AM
bcartman2's Avatar
bcartman2
i pressure wash mine, when i got the car it was nasty under there, i used gunk it made all of the exposed metal look like crap so dont do that. as for the pressure i have only had 2 issues and neither on my c5, first was on a camaro with a cracked coil that shorted out when it got wet and the second was my 89 c4 i got some water into the maf, had to spray it with carb cleaner to dry it out and it was fine.
Old Nov 21, 2008 | 09:14 AM
ohmsby's Avatar
ohmsby
simple green and a hose has always worked well for me I also do not drive in the rain and that helps as well
Old Nov 21, 2008 | 09:27 AM
Muddbug1's Avatar
Muddbug1
St. Jude Donor '08
I used Purple Power, bought at wal-mart. I mixed it with water 50/50, covered my alternator and battery/fuse box compartment, and sprayed down the engine compartment. I waited a few minutes and then sprayed it off. I have one of those fire hose type nozzles and you can just crack it open to get a very small but high pressure stream. This is so you don't blow degreaser all over everything. Works like a champ.
Old Nov 21, 2008 | 10:06 AM
T&C Conv's Avatar
T&C Conv
I wash mine all the time. I only use the LOW pressure at the $.25 car wash. I used to use the high pressure on my Camaro, but I got water inside the connector on the throttle body and it corroded. The seals on the electrical connectors cannot take the high pressure. They will leak and corrode and 1 year from now you will see intermittant problems. BTDT
Old Nov 21, 2008 | 10:19 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Use a good all purposes cleaner and a standard hose with a spray nozzle. Have the engining running while you spray the hose, and move the water away from the area you aredoing if the engine stumbles.
You should not have any problem.
Old Nov 21, 2008 | 11:13 AM
YNOT2K's Avatar
YNOT2K
open hood.
spray simple green at full strength liberally all over engine compartment.
wait 15 minutes. use this time to gather all items necessary to clean the rest of the vette.
use hose with no sprayer attachment and rinse engine compartment completely. this method uses volume of water, not pressure to remove dirt, grease, and grime.
close hood.
wash and dry the rest of the vette. this usually takes me about 40 minutes.
open hood.
dry any areas in engine compartment that are still wet.
works for me!
take it easy,
jeff
To washing engine bay ????
