[Z06] vss wire for gps
Old Nov 21, 2008 | 12:33 PM
Chi_z06's Avatar
Chi_z06
Default vss wire for gps
hey all,
i just got my first vette about 4 days ago, and am super excited.
i found a JVC single-din head unit that has a gps (which i would like to purchase), but my concern with installing the unit is the vss wire.
i have a 2004 z06...is the vss wire accessable if i remove the head unit? is there someone else who has installed an in-dash gps with any tips for me?
thanks for the help in advance!
Old Nov 21, 2008 | 02:04 PM
Vette-kid's Avatar
Vette-kid
check in the Audio/Electronics section (under "General Corvette"). Do a search over there, there have been several write ups on NAV unit installs in the C5. There is also a C5 audio FAQ that may have what you are looking for. Congrats on the Vette, jand the JVC. You wont be dissapointed with either (I have the non NAV version of the JVC unit...and a C5Z)
Old Nov 21, 2008 | 05:52 PM
JUSTAKAR's Avatar
JUSTAKAR
Hope this helps from another vette post.........
You will have to tap into the harness on the instrument cluster. You need to find the Green/white (A7-circuit 817) with a tan/white (A6-circuit 33) above it and a black (A8-circuit 150 ) below it..The other green/white (A10-circuit 357) oil temp has a blank and a gray on each side.
all of the above is accessible from the drivers side knee bolster area....
Old Nov 21, 2008 | 06:07 PM
BitViper's Avatar
BitViper
You may also need the Databus wire..Im looking too
Ive read this too..and it "seems" to be correct...I dont understand it I dont know from A7 or xyz....
Old Nov 21, 2008 | 06:52 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Here is the cluster harness pin diagram (VSS is pin "A7"):
This is the harness you want (driver's side kick panel):
To vss wire for gps
