SMT Switchback Tower problem
Old Nov 21, 2008 | 04:38 PM
gixxer05's Avatar
gixxer05
Default SMT Switchback Tower problem
I have a 1999 FRC with SMT Switchback 30 led Towers installed. However, one side partially works after a day of driving. I took a look and couldn't figure it out why the left is fine and the right side only activates when signaling (blinking yellow) but not for daytime running mode (constantly on led white). So I bought another tower from the vendor. The new tower does the same thing. Has anyone experienced this before or know how I can fix this problem? Any help is appreciated. Thanks.
JM
Old Nov 21, 2008 | 05:15 PM
gixxer05's Avatar
gixxer05
ttt
Old Nov 21, 2008 | 05:30 PM
rpm462's Avatar
rpm462
Have you tried rotating it and replugging it back in? Or swapping the switchback to the other side to see if the problem happens there? If not, then you are having some sort of DRL problem. Maybe one of the contacts or wires going to the plug are loose or pulled out.
I just had a switchback problem myself, it would go out after a few seconds of turning the lights on, think a solder connection must have come loose. Would come right back on if I tapped on it, but then after a few more seconds would dim and go out again. Ordered another one and when got it a few of the LED's on top wouldn't light. Vendor said it was an old non-current model that some how got mixed up with the newer models. Was able to exchange it and finally got one earlier this week that did work all the way.
Old Nov 21, 2008 | 05:38 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Do your DRLs work with regular bulbs? Stick a regular bulb in there and see if it fires up normally. If it fires normally, then I'd switch the side I knew worked, with the side that didn't, to make it isn't another defective bulb.
If it doesn't, then start with the fuses, then check the wiring to make sure nothing is crimped, split, or broken.
Old Nov 21, 2008 | 05:51 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i've read in the past that these lights dont work with our cars. i use the 20 LED switchbacks with no problems.
Old Nov 24, 2008 | 04:54 PM
gixxer05's Avatar
gixxer05
Yep, I tried everything but switching sides. I'll try that next. Could it also be the load equalizers? I initially didn't think it would be, since amber still works. I'm planning on pulling everything from the wiring harness once I find another to install as a end all tell all.
Old Nov 24, 2008 | 07:47 PM
rpm462's Avatar
rpm462
Glad you pointed that out, just realized I have the 20-LED switchbacks also... :o
Old Nov 24, 2008 | 09:15 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
The polarity is probably backwards. Unplug the bulb and rotate.
Are you using a Flasher Bypass or resistors?? I'm using the 48 LED towers and flasher bypass with no problems.
Old Nov 25, 2008 | 09:32 AM
gixxer05's Avatar
gixxer05
Wow, the 48 led tower looks super bright. Did you have any problems installing them? I have resistors from the same vendor. Interesting, I didn't know there was difference in polarity (positive/negative) on the bulb. Is this what you're referring to? The bulb or the resistor?
Old Nov 16, 2009 | 08:13 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I would bank on polarity being the culprit here also. LEDs (like any diode) ARE polarity specific and pass current one way only.
To SMT Switchback Tower problem
