HELP!! reverse gear
Old Nov 22, 2008 | 01:43 PM
sunbbang1's Avatar
sunbbang1
Cruising
Default HELP!! reverse gear
Help me out!!! I have 2001 with M6. Today mornoing I was back up from garage reverse gear woked it good.
But from the work I was try to put reverse gear feel like something block the way to go in. All other gear work fine from first to six. I have no idea and I'm stuck hear at work.
Is it big problm? Do I need to call for tow truck?
HELP!!!!!
Old Nov 22, 2008 | 01:45 PM
damilleniumboy's Avatar
damilleniumboy
How good or bad was your clutch? Can you push the car back by man power, and then go in to 1st as you ussualy do, and then go home from there?
Old Nov 22, 2008 | 01:52 PM
sunbbang1's Avatar
sunbbang1
Cruising
Yes I can push the car and drive it. I try it feel like there is no problem on other gear. But is it ok to drive like that condition?
Old Nov 22, 2008 | 02:02 PM
jraschke11's Avatar
jraschke11
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
Do you have a stock shifter? I had a hurst billet/plus and it would have trouble going in to reverse sometimes. I would just cycle through the gears and then go very deliberately in to reverse and it worked.
Old Nov 22, 2008 | 03:22 PM
sunbbang1's Avatar
sunbbang1
Cruising
Thank you guys. I just try disconnect battery and put back it work.
I have no idea why but its working now. thanks for help me out.
To HELP!! reverse gear
