Can i run on corn?
Old Nov 25, 2008 | 08:31 PM
Dave concrete's Avatar
Dave concrete
Default Can i run on corn?
I just seen the first E-85 gas pump here on Long Island. I'm sure their has been a post on the subject before but I might have missed it. My question is can you just put this in your car or will the computer have a nervous breakdown? I see alot of GMcars stateing their flex fuel cars.
Old Nov 25, 2008 | 09:27 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
I wouldn't.
Just the ethenol additive is enough to make me use fuel system cleaners.
Old Nov 25, 2008 | 09:38 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
Don't do it.It will corrode your fuel line plumbing.Also,computer will not not like it.jerry
Old Nov 25, 2008 | 09:50 PM
Oldvetter's Avatar
Oldvetter
Your seals are not compatable either.
Old Nov 25, 2008 | 10:04 PM
jraschke11's Avatar
jraschke11
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
I wouldn't get E-85 near my car with a ten foot pole.
Just the mandatory additive everyone is putting in nowadays is destroying vehicles. Corroding and eating everything up. Tomorrow I have to drop the gas tank and replace the entire fuel pump in my wifes 1998 malibu because the ethanol corroded everything beyond repair.
Old Nov 25, 2008 | 11:24 PM
djengr's Avatar
djengr
Seems like I saw an article in Vette Magazine about the conversion on a C6. I did not read it so I can not comment on the article, but the previous posters got it right, there are components that get eaten up with ethenal. Here in the southwest we only see the 10% mix. I have not seen any detremental effects, just an assumed worse gas mileage.
Good luck.
Old Nov 25, 2008 | 11:38 PM
damilleniumboy's Avatar
damilleniumboy
Nope.
Old Nov 25, 2008 | 11:51 PM
jrose7004's Avatar
jrose7004
That's what I've heard!
Old Nov 26, 2008 | 12:09 AM
GrayC5's Avatar
GrayC5
See the following. Its currently does not show any Corvette as being a Flex Fuel Vehicle (FFV) capable of using E85:
Do I Have an FFV?
Old Nov 26, 2008 | 12:14 AM
fdxpilot's Avatar
fdxpilot
Here's a 3 page thread on the subject. Do a search on "Ethanol" or "E85" and lots of stuff shows up.
http://forums.corvetteforum.com/c5-t...n-our-c5s.html
Old Nov 26, 2008 | 12:15 AM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Wow some good info here, looks like I'll be staying away from Husky and Mohawk gas stations (tourists you've been warned).
Old Nov 26, 2008 | 12:17 AM
itzza427's Avatar
itzza427
It will cost a lot,,but you will get good MPG,,,,as it's going down the road on the flat bed going to the shop to get your fuel system fixed!!:cheers :
Old Nov 26, 2008 | 12:23 AM
motogib1's Avatar
motogib1
The C5s were not designed as flex fuel vehicles so it would require modifications to run on E-85. Anyway why would you want to, your gas mileage would go down by 25%. E-85 is an ill conceived alternative from day 1.
Old Nov 26, 2008 | 12:25 AM
dobewillie's Avatar
dobewillie
please don't
Old Nov 26, 2008 | 09:08 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
I wouldn't do it !
Old Nov 26, 2008 | 10:20 AM
Sidewayz6.0's Avatar
Sidewayz6.0
Thats true, the gas mileage is much less. However, the idea is that the money you spend on E85 stays here, supporting American farmers, and not foreign oil.
What's it really worth to you?
Old Nov 26, 2008 | 02:07 PM
The Corvette is not set up to run on E-85. It will run on 10% ethanol just fine.
Old Nov 26, 2008 | 09:21 PM
Dave concrete
I don't have any intention on using it, I just seen it here for the first time and was curious.
To Can i run on corn?
