99 Sun Visor
Old Nov 26, 2008 | 06:38 PM
simard's Avatar
simard
Default 99 Sun Visor
I have a 99 vert that needs a new drivers side sun visor. I have the new visor,how does the old one come off? Is a new trim ring required?
Thanks,
Bob
Old Nov 26, 2008 | 07:06 PM
Jet-Jock's Avatar
Jet-Jock
There is a slot. Insert a flat blade screwdriver which is to hold the ring in place while you rotate the visor toward the door side (like your blocking sun coming from the side). It will drop down a notch, then rotate it slightly more and it will drop out. Disconnect the electrical connector.
I'd have to go look but I seem to remember it says something about installing a new ring. The old will probably work. Just reverse the procedure to install.
Old Nov 26, 2008 | 07:08 PM
dobewillie's Avatar
dobewillie
jet hit the nail on the head good luck
Old Nov 26, 2008 | 08:55 PM
simard's Avatar
simard
Default Thanks
Thanks for the help. Once you know what to do, it is really easy.
You guys are really helpful.
Happy Thanksgiving
Old Nov 26, 2008 | 09:58 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
I wrapped tape around the arm of my visor during removal because I was reinstalling the originals.
Hold the flat-bladed screwdriver in the ring tab (or slot) and as the other poster said, move the visor towards the door as if you were going to block out the sun. The arm will push on the screwdriver shaft, loosening the ring.
Carefully fish out the connector from the hole.
Click for the BIG pic.
Old Nov 27, 2008 | 12:38 AM
Steve karp's Avatar
Steve karp
Cruising
Go to Ecklers page where they sell them and there is a PDF of instructions.
http://www.ecklers.com/assets/pdf/46080.pdf?
Old Nov 27, 2008 | 09:33 AM
Jet-Jock's Avatar
Jet-Jock
Excellent, illustrated instructions are so much better.
To 99 Sun Visor
