Every once in a while i will get into my 01 z06 and it will not crank, everything turns on but it will not crank. i have to push the clutch about 5-10 times before it will finally turn over. Im guessing there is some problem with the switch that tells the computer the clutch is engaged so it will let the car start. Does anyone else have any input on this. Thanks
Could be the switch or some other problem.
You can pull connector and jump the curcuit by connecting a little jumper lead or test lead the next it does not work and see if this solves your problem.
