[Z06] Alternator???
Old Nov 28, 2008 | 09:44 AM
acano1728's Avatar
acano1728
Default Alternator???
Well. . .i was driving down the highway when my Z started to feel like it was missing, maybe more than one cylinder. The check engine light and check gauges light came on. The message center said something like "check motors power supply" (not exactly like this). Any how. . .the voltage reading on my radar detector began to drop more apparent than on the actual voltage gauge. . . . I understand that everything points to the alternator, but why is the engine missing, knocking. And why does it still crank fine why i try to start it?
Old Nov 28, 2008 | 11:08 AM
TEXHAWK0's Avatar
TEXHAWK0
Have you checked the battery voltage with the engine off, and voltage across the terminals with the engine running?
Seems like you would need that as a baseline before looking further.
Old Nov 28, 2008 | 03:44 PM
lbarnard's Avatar
lbarnard
Check and see if you have a cracked plug too. Check for loose plug wire as well.
Old Dec 1, 2008 | 08:20 AM
acano1728's Avatar
acano1728
ttt
Old Dec 1, 2008 | 10:42 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would check all of your connections. What is the voltage reading on your gage on dash ? Should be hanging around 14.0V
Old Dec 1, 2008 | 11:06 AM
steelankles's Avatar
steelankles
If engine starts battery prolly is good, if alternator is failing it can cause those problems. Check voltage with engine on has to be more than at least 13.0volts at idle. I see on mine 14.0 - 14.8 normailly. Sometimes voltage can be good and alternator is still bad. How many miles do you have on the car?
Old Dec 1, 2008 | 11:42 AM
acano1728's Avatar
acano1728
^^ 50K miles.
To Alternator???
