copetition mode???
Old Nov 29, 2008 | 11:46 PM
Originally Posted by fdxpilot
Just to be clear, if the Vette has active handling, then "competition mode" is available. No AH, no competition mode. It was an option from 98-2000, and standard after that.
Good recap.
Old Nov 30, 2008 | 09:43 AM
steve8's Avatar
steve8
Another tip is once in comp mode, you can hit the reset button to remove it from the dic. This does not disable it, just allows you to use/see the other functions.
Old Nov 30, 2008 | 12:42 PM
Vega$Vette's Avatar
Vega$Vette
Originally Posted by deadbeatrec
i know but its far from what i had asked. i know where the traction control button is, i didnt know if there was an active handling button like the one article link i posted said there was.
Please post pics of the crash. Hope no one gets hurt
Old Nov 30, 2008 | 12:44 PM
deadbeatrec's Avatar
deadbeatrec
again with the asinine posts.
Old Nov 30, 2008 | 01:15 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
You should try posting in OT, your thin skin will go over real well over there.
Old Nov 30, 2008 | 02:06 PM
itzza427's Avatar
itzza427
Another small point, Not sure of the exact year,,but I believe prior to 01 to activate Comp Driving mode you have to be stopped to activate.I know in my 2000 that is the case. I believe from 01 on you can be going slow and engage it. To answer the one question, yes it disengages when you turn the key off ,That's why I always wait till I'm 2nd in line in the staging lane. I put it in Comp Driving mode,hit reset to monitor engine temp and am ready to GO!!!
Old Nov 30, 2008 | 02:35 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You don't say what year your car is - if it is a '97 or an early '98, Active Handling (RPO JL4) was not available, and as a result, Competitive Driving mode is not available. It was introduced on the later '98s and became standard in 2001.
When it became standard - it was the second generation of Active Handling, was less intrusive, and could be activated while rolling at low speeds.
As mentioned - if you hold down the button, you will get the Competitive Driving message on the DIC. A single push disables both traction control and active handling. Both come back on when you restart the car as both engaged is the default.
Active Handling utilizes yaw sensors and applies brake to the opposite front wheel depending on the direction of the spin.
Competitive Driving disables T/C and leaves A/H enabled.
Old Nov 30, 2008 | 03:13 PM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
competitive driving mode on mine feels more like sluggish acceleration mode. on mine, the throttle response is better in either regular mode or with t/c off. I guess I could delete the torque management, but I dunno if I'm that brave...
Old Nov 30, 2008 | 06:05 PM
deadbeatrec
o really? thanks, ill head right over there
Old Nov 30, 2008 | 08:10 PM
Bell's Avatar
Bell
TC/AH was not available on all years.
Traction Control and Active Handling are enabled/disabled using the same button.
Traction Control prevents wheel spin by reducing spark and fuel.
Active Handling monitors wheel speed sensors, steering wheel position, yaw sensor to determine whether the car is going in the direction the driver is trying to steer the car - if not, it applies one of the four brakes all on it's own to try and get the car pointed in the right direction.
Competition Driving mode is entered by pressing the same TC/AH button but holding it in for 5 to 10 seconds.
For drag racing, you'll need to turn TC off or you can't do a burnout. With stock engine and 2.73 gears - just leave TC/AH on because the car doesn't have enough torque to cause wheel spin issues as long as the track is halfway prepped. Once modded (either bigger gears or more hp), even with drag radials, eventually wheel spin will become an issue. Also if you spin off the line, the TC will bog the engine causing VERY slow ETs - letting the wheels spin without bogging the engine is better. I use Competition Driving mode because I need TC off for burnout, but want AH on to save me if the car goes squirrelly.
Old Nov 30, 2008 | 08:42 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
i just got the car but thanks for the useless post!
He is telling you the truth.......
Old Nov 30, 2008 | 08:46 PM
deadbeatrec
how do u figure? are u assuming that i am irresponsible and do not know how to drive? for all u know i have been racing cars all my life. u dont know me, non of u do and to make an assumption like so is stupid and immature. so i will drive my car as i wish, with or with out any type of traction control, active handling or competition modes. thanks for being concerned but im far from worried.
Old Nov 30, 2008 | 08:52 PM
  #33
moserbe's Avatar
moserbe
Old Nov 30, 2008 | 08:55 PM
  #34
moserbe's Avatar
moserbe
Mellow out a little. We might be able to know you a little better if you put more information in your profile. Enjoy your Corvette and drive it any way that you like.
  #35
mnfmkf's Avatar
mnfmkf
Some of what I am reading here sounds a wee bit wild to say the least. .
CORRECT INFORMATION IS WORTH ALOT....
I SUGGEST
Get one of the VHS tapes that GM supplied with the car.
(They come up on Ebay )
The tape will explain Competition mode very well.
Thats if you can find a VHS player.
Thanks,
Mike
Old Nov 30, 2008 | 08:57 PM
  #36
Mr.Bill's Avatar
Mr.Bill
OK DeadBeat
First off you need to take a chill pill, I took his statement as an in general statement, You would be surprized how many members post that lost control of there car because they didn't expect what happened... If the shoe fits cool then, If not don't take it personal. , Now go and take that chill pill.
Old Nov 30, 2008 | 09:24 PM
  #37
deadbeatrec
OK DeadBeat
duely noted and i didnt mean to make it personal. but know that i have had a few high high hp street cars and i know how to control them. im not about to do something stupid so no worries.
so about that chill pill, where can i get some? haha
Old Nov 30, 2008 | 09:57 PM
  #38
bill bradford's Avatar
bill bradford
Do not turn off the competitive mode. You will lose traction and control. Unless, of course, you are a trained professional racer. I attempted it and about lost it.
