Window does not seal
Old Nov 29, 2008 | 11:23 PM
Les One S's Avatar
Les One S
2nd Gear
Default Window does not seal
Sometimes when I close the door the window catches on the small plastic (I cannot rember what they are called) a leaves an opening. Doesn't happen all the time, usally when it rains.
Old Nov 30, 2008 | 03:03 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Blow out clip? It can be adjusted... lift the weatherstripping.
Old Nov 30, 2008 | 07:34 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Your blow out clip is pushed in too far. Two way to move it. 1: Wrap a pair of pliers in a cloth, grab the clip, and gently pry it outward just a touch. Don't pull it out too far or your window won't seal, and you'll get noise at speed.
2: Lift the weatherstripping until you can see the two screws that hold the clip to the roof. Loosen the screws until you can slide the clip outward a little. Open and close the door until you get the right clearence, then re-tighten the screws, and replace the weather stripping.
HTH
Old Dec 1, 2008 | 12:26 AM
Les One S's Avatar
Les One S
2nd Gear
Default Thanks
Thanks for both your help
To Window does not seal
