Upgrade tensioner
Old Dec 1, 2008 | 01:41 AM
67silverandblack's Avatar
67silverandblack
Default Upgrade tensioner
Been having a burning rubber smell for awhile. Drive belt finally slipped badly & started shredding. I replaced it & blew out all the dust. It's been a few weeks & I still smell the burning rubber smell. Not sure if it is still slipping since I don't see any belt dust.
I am wondering if I should replace the tensioner. I noticed I can push down on it. It does take some effort though but I was able to release the belt without using a 15mm socket & wrench on the pulley. Just pushed down on the pulley itself. Is this a problem & should i try a more stout tensioner?
Thinking about a C6 or maybe the Total Performance one I saw on here.
Old Dec 1, 2008 | 04:49 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
How about the one by Katech?
Old Dec 1, 2008 | 09:46 AM
hattitude's Avatar
hattitude
Do you believe that your belt is slipping?
If so there are aftermarket tensioners...... or you can use the C6 tensioner. It is supposed to be a little more stout versus the C5 tensioner and the pulley has lips to help keep the belt from coming off the pulley.
Did you check all the pulleys when you replaced the belt to make sure one isn't failing/binding?
Good luck with the fix...
Old Dec 1, 2008 | 10:49 AM
4DRUSH's Avatar
4DRUSH
This will fix you up. Give ECS a call.
http://www.eastcoastsupercharging.co...tensioner.html
Old Dec 1, 2008 | 09:50 PM
67silverandblack
I don't believe it is, but I figure since the same smell is there from when it was slipping that it still is.
Just looked into it & they don't recommend it with the maggie
I didn't know about this one. Looks very interesting.
thanks
Old Dec 2, 2008 | 01:57 PM
Independent1
St. Jude Donor '08
^^Sorry about that. Did not know you had a maggie since you did not mention that in your OP.
Old Dec 2, 2008 | 02:00 PM
bucwheat's Avatar
bucwheat
That would make a diff.
To Upgrade tensioner
