History Report
Post every now and again and finally in the position to purchase a car im looking at. Price is a little low and the initial carfax says 31 entries...Car is located in Salisbury (sp?), NC. VIN is
1G1YY22G025105587
Any help is greatly appreciated.
132882
C1420 - WEATHERSTRIP, HATCH OR FRONT ROOF PANEL - RIGHT - REPLACE
35984 miles
03/02/2005
131965
L1203 - SENDER AND/OR PUMP ASSEMBLY, FUEL (TANK UNIT) - BOTH TANKS
35962 miles
03/02/2005
131965
N3230 - ACTUATOR ASSEMBLY - HEADLAMP - RIGHT - REPLACE
35962 miles
03/02/2005
131965
C1421 - WEATHERSTRIP, HATCH OR FRONT ROOF PANEL - LEFT - REPLACE
35962 miles
01/22/2005
130571
C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE
35862 miles
01/06/2005
129986
C0221 - GUIDE, FRONT DOOR WINDOW - LEFT - R&R OR REPLACE
35646 miles
01/06/2005
129986
B1321 - HOUSING - HEADLAMP - LEFT - R&R OR REPLACE
35646 miles
08/18/2004
124868
H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT
33217 miles
08/18/2004
124868
N3231 - ACTUATOR ASSEMBLY - HEADLAMP - LEFT - REPLACE
33217 miles
08/18/2004
124868
B1500 - HOOD AND/OR LATCH ASSEMBLY - ALIGN/ADJUST
33217 miles
08/18/2004
124868
C0183 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - LEFT SIDE
33217 miles
08/18/2004
124868
B7010 - EMBLEM AND/OR NAMEPLATE - ONE - REPLACE
33217 miles
01/13/2004
116646
C2020 - SUNSHADE REPLACEMENT - RIGHT SIDE
28356 miles
12/29/2003
909469
T2020 - TOWING
15000 miles
12/26/2003
116088
N0110 - BATTERY REPLACEMENT
27363 miles
12/26/2003
116088
E7200 - IGNITION LOCK CYLINDER REPLACEMENT
27363 miles
06/09/2003
108283
C0100 - GLASS, FRONT DOOR - RIGHT - ALIGN
21675 miles
05/01/2003
106722
N2610 - WINDSHIELD WIPER AND WASHER SWITCH REPLACEMENT
20952 miles
05/01/2003
106722
Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY)
20952 miles
03/11/2003
104682
19205 miles
07/02/2002
079091
10426 miles
06/17/2002
078425
D3020 - AIR CONDITIONING REFRIGERANT SERVICE VALVE CORE REPLACEMEN
9851 miles
04/25/2002
076293
E2020 - WHEEL ALIGNMENT MEASUREMENT
7368 miles
08/30/2001
A05587
I
Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Now...the headlight motors and stuff dont bother me...but the fuel stuff, along with the traction control and TOWING line...
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2002 CORVETTE COUPE Warranty Start Date : 10/04/2001
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : SIR WALTER CHEVROLET COMPANY
PO BOX 90367
RALEIGH , NC 27675-0367
(919) 787-3700
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
03/24/2005 132882 # C1420 - WEATHERSTRIP, HATCH OR FRONT ROOF PANEL - RIGHT - REPLACE 35984 miles
03/02/2005 131965 # L1203 - SENDER AND/OR PUMP ASSEMBLY, FUEL (TANK UNIT) - BOTH TANKS 35962 miles
03/02/2005 131965 # N3230 - ACTUATOR ASSEMBLY - HEADLAMP - RIGHT - REPLACE 35962 miles
03/02/2005 131965 # C1421 - WEATHERSTRIP, HATCH OR FRONT ROOF PANEL - LEFT - REPLACE 35962 miles
01/22/2005 130571 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 35862 miles
01/06/2005 129986 # C0221 - GUIDE, FRONT DOOR WINDOW - LEFT - R&R OR REPLACE 35646 miles
01/06/2005 129986 # B1321 - HOUSING - HEADLAMP - LEFT - R&R OR REPLACE 35646 miles
08/18/2004 124868 # H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT 33217 miles
08/18/2004 124868 # N3231 - ACTUATOR ASSEMBLY - HEADLAMP - LEFT - REPLACE 33217 miles
08/18/2004 124868 # B1500 - HOOD AND/OR LATCH ASSEMBLY - ALIGN/ADJUST 33217 miles
08/18/2004 124868 # C0183 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - LEFT SIDE 33217 miles
08/18/2004 124868 # B7010 - EMBLEM AND/OR NAMEPLATE - ONE - REPLACE 33217 miles
01/13/2004 116646 # C2020 - SUNSHADE REPLACEMENT - RIGHT SIDE 28356 miles
12/29/2003 909469 # T2020 - TOWING 15000 miles
12/26/2003 116088 # N0110 - BATTERY REPLACEMENT 27363 miles
12/26/2003 116088 # E7200 - IGNITION LOCK CYLINDER REPLACEMENT 27363 miles
06/09/2003 108283 # C0100 - GLASS, FRONT DOOR - RIGHT - ALIGN 21675 miles
05/01/2003 106722 # N2610 - WINDSHIELD WIPER AND WASHER SWITCH REPLACEMENT 20952 miles
05/01/2003 106722 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 20952 miles
03/11/2003 104682 # N3230 - ACTUATOR ASSEMBLY - HEADLAMP - RIGHT - REPLACE 19205 miles
07/02/2002 079091 # N3230 - ACTUATOR ASSEMBLY - HEADLAMP - RIGHT - REPLACE 10426 miles
06/17/2002 078425 # D3020 - AIR CONDITIONING REFRIGERANT SERVICE VALVE CORE REPLACEMEN 9851 miles
04/25/2002 076293 # E2020 - WHEEL ALIGNMENT MEASUREMENT 7368 miles
08/30/2001 A05587 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1673 kg (3689 lb) Order Number : DNNRN1
Build Date : 08/30/2001 Build Plant : 125Y
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B84 - BODY SIDE MOLDINGS
CC3 - TRANSPARENT LIFT-OFF ROOF PANEL CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE LOW EMISSION VEHICLE
GU2 - REAR AXLE 2.73 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF7 - FEDERAL EMISSION SYSTEM NLEV
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QF5 - POLISHED ALUMINUM WHEEL SLM - STOCK ORDERS
T82 - TWILIGHT SENTINEL T96 - FOG LAMPS
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - COMPACT 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN
19I - BLACK INTERIOR TRIM 193 - BLACK LEATHER TRIM SEATING
21U - ELECTRON BLUE METALLIC
Actually found one here locally. Think it's the original owner. VIN is 1G1YY22G525111062. but im sure no one is at work...hopefully..
