Tranny problems!!
Dec 3, 2008 | 09:19 PM
Tranny problems!!
It all started with 6th gear making a clicking noise when i shifted into it and it felt like it was trying to kick it our. Now i cant even shift into 6th, and 5th gear is starting to do that same clicking noise and feeling like it wasnt to kick it out of gear. Some people say its the syncros, i have had person say it sounds like and adjustment problem.... any ideas before i take her into the shop?? thanks! i have an 04z w/ 30k miles
Dec 3, 2008 | 10:27 PM
St. Jude Donor '05-'06-'08
Dec 3, 2008 | 10:35 PM
where are they located......or any reccommendations in that austin texas area for good tranny shops?
Dec 3, 2008 | 10:42 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Quote:
Originally Posted by
MIKE-C5
Call RPM Transmission
Dec 3, 2008 | 10:51 PM
St. Jude Donor '08
JustinZook
Sounds like a bad fork pad.
Rebuild time.
Dec 3, 2008 | 11:08 PM
What would cause the fork pad to wear out at 30K?
Dec 3, 2008 | 11:10 PM
St. Jude Donor '08
Jet-Jock
Not so much wear out as they crack, they are made out of cheap plastic. RPM replaces with bronze, I think.
Dec 3, 2008 | 11:21 PM
So would a hard shift or something would cause it to crack?
Dec 3, 2008 | 11:33 PM
St. Jude Donor '08
Jet-Jock
Could be a hard shift, or a real cold day and you jam the shifter to hard, etc ...
The fork pads are what lock and hold the fork in place. If the car keeps trying to jump out of gear this may be your problem.
Dec 4, 2008 | 07:24 AM
How much $$$ we lookn at her for the fork pad
Dec 4, 2008 | 07:47 AM
St. Jude Donor '08
JustinZook
They're cheap, however all of the labor to R&R the tranny is going to be high.
Don't know how old your clutch set-up is but it's probably a good idea to update that at the same time.
RPM can handle tranny rebuild for you and I would recommend them based on my own personal experience with them.
http://www.rpmtransmissions.com/c5pricing.html
Dec 4, 2008 | 07:57 AM
Dec 4, 2008 | 08:44 AM
St. Jude Donor '08
JustinZook
Where r they located?
They're in Indiana. They send you a Fed-Ex ticket and you just drop tranny off, they fix it and send it back.
Elsewise I find a local vette shop and they can do work and send it out to RPM for work.
Gulfcoast Corvette (Jason & Steve) may be near you and do excellent work.
