No Start-What Am I Missing???
Old Dec 3, 2008 | 09:48 PM
belmor's Avatar
belmor
Default No Start-What Am I Missing???
Ok, my 1998 Coupe has had a no start issue for a long time now,
Sometimes it starts perfectly, sometimes it will act like the battery is dead and not turn over at all.
Here is what I have done:
Tested battery
Tested Alternator
Replaced battery (issue got better, then went back to bad)
Replaced battery terminal on positive side
Replaced both battery cable assemblys (old ones corroded/scorched looking this helped some, but not fixed issue)
If you get in the car and it will not start a boost will fire it up fine.
The battery is not down when the car won't start and sometimes if you let it sit a minute it will fire right up.
I suppose the next thing to replce is the starter but surely if the starter was bad it would be bad all the time, not some of the time
Is there something I am overlooking, a bypass relay or something else that could be causing this issue? It has totally taken the fun out of this car, I am honestly ready to get it fixed and sell it, I have put less than 1k miles on it this year beacuse of it.
Thanks in advance!
~B~
Old Dec 3, 2008 | 09:55 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Tested battery
Tested Alternator
Thanks in advance!
~B~
Auto or six speed ?
Could be bad ignition switch or ground. Also starter may be going requiring more current to start.
What size battery (CCA) Cranking Amps. Electrical problems suck because they could be one thing or multiple items.
Old Dec 3, 2008 | 09:56 PM
dperetti's Avatar
dperetti
Could be a starter armature with a bad segment. I had a similar problem on an older Chev small block, but don't know if newer starters can act the same.
Old Dec 3, 2008 | 10:02 PM
trk982003's Avatar
trk982003
could be the starter enable relay or theft deterrent relay (i think theyre the same thing.) its in the passenger side footwell above the fuses in a rather tight spot. should have a heavy purple wire along with some others. if you put power right to the purple one it should crank whether the car is off or in gear so be careful. have someone listen for it clicking while you try starting. also if its an auto try starting in neutral. if you have an autostarter or aftermarket alarm they have been known to fail too. good luck
Old Dec 3, 2008 | 10:06 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
This may sound....dumb, but if it's a 6-speed make sure you have the clutch fully engaged.
Old Dec 3, 2008 | 10:18 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
When you say it doesn't "start", do you mean the engine is turning over but not firing, or do you mean it doesn't even turn over?
Old Dec 3, 2008 | 10:46 PM
belmor's Avatar
belmor
The engine will turn once just but never make a full revolution, just like a low battery would act, but I have tried more than one battery in the car and the results are the same
The car is a 6 speed with no aftermarket alarm or autostart
I feel like if it were a ignition switch or relay the starter would never engage but I am not a mechanic.
When we changed the battery cables tonight there were noticable heat marks on the starter but when it works it works like a new car
~B~
Old Dec 3, 2008 | 10:47 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
~B~
Sounds like a flat spot in the starter.
Old Dec 3, 2008 | 10:51 PM
Jet-Jock's Avatar
Jet-Jock
Or an issue with the clutch pedal switch, or a ground. Do a search for ground issues there is a great post on this that shows the ground connectors! Electrical cars like good grounds.
Old Dec 3, 2008 | 11:04 PM
trk982003's Avatar
trk982003
Old Dec 4, 2008 | 12:00 AM
Oh 2 Fun's Avatar
Oh 2 Fun
Okay....I see that this narrows down the troubleshooting since it only barely turns over the engine.
Offhand, it sounds like a battery "load" problem but you squelch that with your battery changes etc.
Plus you've addressed the relay(s).
This could go any number of directions...such as....and this is extreme...is your engine moisture locked due to a cracked head(s) whereby it compresses H2O and stops....hence...remove the plugs and see if the starter cranks the engine easily......
that is the extreme, but it seems you need to figure out if it is electrical or because the engine doesn't want to turn over. So far, with what you've said about "boosts", it seems electrical (i.e. solenoid, relays, starter windings, etc.) Have someone test the draw from the starter. It might be toast.
I like to talk out me ****, but just throwing out ideas.
good luck...and let us know what the final prognosis is.
Old Dec 4, 2008 | 12:32 AM
hightest's Avatar
hightest
Based on what you've already tested, it could only be a few other items.
- neutral safety switch is bad.
- dirty starter brushes.
- bad ground.
Old Dec 4, 2008 | 09:06 AM
bucwheat's Avatar
bucwheat
Neutral safety switch or starter issue,the starter may test fine but have a bad spot.
Old Dec 4, 2008 | 12:48 PM
Mike McCoy's Avatar
Mike McCoy
Don't forget the caution floating around here a while back. Some new batteries have terminal bolt holes that are not machined deep enough. The cable bolt bottoms out before the cable makes a good firm contact. I had all the symtems of a bad battrey before I installed a thin washer over the cable bolts. The cable is now solid and I have no more battery problems.
To No Start-What Am I Missing???
