Is it true!!
Old Dec 5, 2008 | 10:45 AM
Borrega's Avatar
Borrega
Default Is it true!!
Well im not sure if its true but a buddy of mine told me that heads from a 5.3 truck are little better then the stock corvette heads is it true...
Old Dec 5, 2008 | 10:48 AM
Dominic Toretto's Avatar
Dominic Toretto
Does he have any flow tests or dyno tests to prove his claims?
-Alex
Old Dec 5, 2008 | 11:58 AM
sublime1996525's Avatar
sublime1996525
from what I know they are better than the 241 heads but not as good as the 243's. don't have any flow numbers though.
Old Dec 5, 2008 | 12:07 PM
Corvette Don's Avatar
Corvette Don
They only flow better when cnc ported and are milled a tad for higher compression than the LS1 heads.
Old Dec 5, 2008 | 12:27 PM
GKE's Avatar
GKE
They flow better when ported, but the main item of interest is they bump compression a bit. That can be good or bad depending on your build goals. I have the 5.3 heads fully ported by TEA and they raised compression to 11.1:1 but they also flow much more than ported 243's.
To Is it true!!
